strange valve noise
tapping in motor so i pulled valve covers and found the
recently adjusted valves out of spec again i thought the nut had losened but it was still tight so i thought i had wronly set the clearance on further examination if i push on the cam side of the rocker arm it seems to make contact but if i keep pushing in it like clicks and goes in further making a loud clanging noise is it possible the cam tower is worn and my cam is teeter tootering on the middle bearing or is it more likley that the rocker holding pin or rocker is worn oblong causeing the double movement and subsequent loud clang thanks for any and all input tony
89 Mercedes 300E 77 911s TARGA 79 3.2 widebody 79 911 SC TARGA 97 BMW Z3 Last edited by tony77targa; 10-06-2003 at 02:03 PM.. |
Author of "101 Projects"
911 Engines don't have tappets (cam followers), do you mean the rocker arm?
If you push against the cam, are you saying the camshaft is loose? I can't tell from your description here... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
yes rocker arm
Wayne I cant tell if the cam is moving or if the rocker arm is moving back and forth on the shaft the loud noise when pushing in on the rocker is louder than what seems it should be for the rocker to be hitting the cam thats why i thought it was the cam moving plus there seems to be hitch halfway down and then the loud clang. i was just wondering if there was a common problem with this scenario before i dig deeper thanks for the help tony
89 Mercedes 300E 77 911s TARGA 79 3.2 widebody 79 911 SC TARGA 97 BMW Z3 Last edited by tony77targa; 10-06-2003 at 03:53 PM.. |
