Banned
Torque Questions
Hello ,
I have a few question on what certin bolts/nuts are torqued to, I have a few manuals and none say what these bolt/nuts are torqued to? Pretty soft just to tighten them up , the engine is 69 911E 2.0
10 - 13mm nylon nuts timing chain housing to block.
4 - 15mm chain rails bolts into the block
6 - 10mm bolts behind the cams spocket holding the aluminium plate and seals.
thanks
Dave
Old 10-09-2003, 10:36 PM
Banned
sigh.... Does anyone have this book??? If so could you look in it a give me the numbers I need
thanks
Old 10-10-2003, 08:26 AM
