Send a message via AIM to dtfastbear Send a message via Yahoo to dtfastbear
Missed shift - how bad is the damage likely to be?
My wife accidentaly caught 2nd instead of 4th on an intended upshift from 3rd gear exiting turn 9 at Thunderhill this past weekend. The resulting over rev did some serious damage, it seems. The car wouldn't really start after she limped it into the pits. We pushed it onto the trailer and dropped it at our mechanic's shop.
What are the best and worst scenarios for such an incident? I'm assuming most of the valve train is toast, but what else can be damaged? The pistons? Can valve to piston contact mess with the rods or the bottom end?
I'm sure our mechanic will give us the full prognosis in a couple days when he tears it down, but I'm curious as to what we're in for...
Thanks,
Dean
'86 Carrera cab (euro)
Spec Miata
Old 10-21-2003, 04:43 AM
jluetjen's Avatar
You're going to need to take it apart no matter what, so my prediction is not going to mean a whole lot at the end of the day.
You just need to keep taking things apart until you don't find anything more damaged. At a minimum your looking at a top end (heads, P&C) for one cylinder. But I'd also have that rod checked for straightness and crack tested, so that will need to come out too. The other thing is to pull the sump and check carefully for any debris there. If there is, you'll need to pull the whole bottom end apart to get that cleaned out as well as the oil system.
But you won't know until you start taking things apart. I'd budget for a full rebuild and then be pleasently surprised if it doesn't need to be done.
Good Luck...
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-21-2003, 06:15 AM
Glenn from Denv's Avatar
As with anything...it depends!
You may have broken rockers (the best news) or may need to get at the bottom end (the worst news)...you won't really know until it's opened up.
_______________
Glenn from Denver
94 964 3.8 RSR
Old 10-21-2003, 06:16 AM
Slumlord
Porsche_monkey's Avatar
My guess, (based on last months similar experience) some new valves at a minimum, and a whole bunch of stuff that 'should' be done when you rebuild the top end. If you ahve case leaks or any bearing wear now would be the timne to address all that also...
I hope I am wrong, but this will probably be rather expensive. On the other hand, if your car is otherwise in good shape, you will be ready for the 100,000+ miles.
Buy Waynes book ASAP, it will pay for itself immediately and give you some confidence in deciding what to have done to your engine.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 10-21-2003, 07:00 AM
This shift has been done before by many others. You're not alone. Hopefully, the damage will be restricted to the top end (rockers, valves), but pistons are a distinct possibility.
Chris Streit managed to document his mis-shift experience.
Sherwood
http://members.rennlist.org/911pcars
Old 10-21-2003, 12:21 PM
dtw dtw is offline
GAFB
[ForestGump]Mechanical overrevs are like a box of chocolates; you never know what you're gonna get...[/ForestGump]
Several BMWs
Old 10-21-2003, 12:51 PM
Thanks for the input guys, although it is not all good news
The shop is tearing down the engine today, so I should have more info. Good idea RE Wayne's book - it pays to be informed!
Dean
Spec Miata
Old 10-22-2003, 08:09 AM
Slumlord
And the result was/is....?
84 Cab - sold!
Old 10-24-2003, 05:21 AM
They pulled the valve covers and... bad news, no broken rockers. So, I guess that means the valves are probably pretty badly damaged.
We won't have the engine completely apart until mon/tues, so I still don't know the full extent of the damage. It doesn't look good, though.
I'll update the thread as soon as the engine is apart...
Dean
Spec Miata
Old 10-24-2003, 06:41 AM
I went to see my poor engine last night, and the damage was not as bad as I thought it might be...
All six exhaust valves are bent to some degree. All six, of course, made contact with the pistons. The pistons do not seem scarred badly at all. My mechanic was pretty certain that we could reuse the pistons and cylinders.
So, the heads are being sent off for new valve guides, and I'll obviously replace all the valves. The head studs, too, are going to be replaced.
My mechanic thinks it would be a good idea for us to "do the rods" because a) the pistons DID take a shot from the exhaust valves and b) the engine has 174k miles on it.
We use the car mostly for track work, but that is likely to only be the case for another year, then it'll go back to a street car once we have a proper race car. Everything is being rebuilt bone stock.
Thoughts? Is it worthwhile to take the rods out and put in new rod bearings?
Thanks,
Dean
Spec Miata
Old 10-30-2003, 07:11 AM
Irrationally exuberant
ChrisBennet's Avatar
If you think you can avoid having another missed shift, go with stock valve springs. If you're like me, missed shifts at the track with a 915 transmission are going to happen. A set of "racing" valve springs will reduce the chance of valve float. I've missed quite a few shifts with my motor. I'm convinced that my AASCO valve springs have paid for themselves.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-30-2003, 07:29 AM
Slumlord
Inspect and measure and them. My guess, based on my own recent experien$e, and the relative strengths of rods vs valves, would be that the rods are still A1. Was there a prize for the closest prediction? If so I could email my shipping address.
84 Cab - sold!
Old 10-30-2003, 07:31 AM
Thanks, guys. Is there any downside to installing racing valve springs other than having to buy them? I mean, do stiffer springs here sap off any appreciable horsepower or anything like that?
PBH - I'd be happy to send you the "most bent" valve to add to your collection. Oh wait, it's Chris who has the collection given his tendancy to miss shifts...
Dean
Spec Miata
Old 10-30-2003, 07:40 AM
Since the rod bearing are easy enough to replace, I would do it. Rod bearings are pretty cheap, especially since the engine is apart..
Chris
Old 10-30-2003, 07:44 AM
Slumlord
No shortage of bent valves in my shop, thanks for the offer though.
84 Cab - sold!
Old 10-30-2003, 07:55 AM
Dean
Surprisingly, I don't think I've never bent a valve from missing a shift. One of the downsides of having a smooth shifting 915 is that you can go into just about any gear at any speed...
Stiffer valve springs are going to cause a little more friction and valve train wear.
-Chris
Old 10-30-2003, 08:04 AM
"Surprising" is right! You should be buying lottery tickets for every draw. I've missed 2 shifts (going for 4th and hit 2nd) and creamed valves each time!
_______________
Glenn from Denver
94 964 3.8 RSR
Old 10-30-2003, 10:50 AM
My valve springs have saved my valves in some cases I'm sure. I've been able to push the clutch in pretty quick other times.
-Chris
P.S. I've never lost on the lottery.
Old 10-30-2003, 11:39 AM
Ho Hum 74's Avatar
Here's how I shift from 3rd to 4th and I've never miss-shifted. But then there are those that say there are two types of pilots: Ones that have done a wheels up and those that are about to! Touch wood.
When doing this shift a racing instructor told me to rotate your wrist 180 degrees so that your thumb is pointing downward and your palm is facing the passenger door. Then it is natural to pull away from your body because all the pressure is on your palm which is facing the passenger door and the rear seat. Very difficult to reach 2nd from that position. Try it 60 times a day for 7 days and you'll never shift any other way because you'll develop the muscle memory to do it automatically.
Happy shifting!
Tristan
Old 11-05-2003, 12:33 PM
