Bird. It's the word...
Fishcop's Avatar
Euro P&C's?
What is the difference between 2.7 p&c and "Euro" 2.7 p&c?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 10-26-2003, 10:14 PM
Author of "101 Projects"
Wayne 962's Avatar
I think I looked this up recently. There is no Euro P&C for the 2.7. There's the 911S and 911 pistons which have different compression ratios. The USA vs. Euro argument comes out when you're talking about 3.0 and 3.2 engines...
-Wayne
P.S. Unless, you're talking about the Euro Carrera MFI, which are MFI-based pistons, and won't work with CIS. What's the real question here?
Old 10-27-2003, 03:31 AM
Fishcop's Avatar
I'm taking delivery of a ROW (Japan) 74 2.7 CIS engine with 68,000 kilometers which I plan to rebuild as per your book. I'm lining up S cams and I have a set of webers to use, so I guess the question is; given the low kilometers, the pistons and cylinders should be well in spec, however I was looking to up compression and don't know where to go from here... are the CIS cylinders appropriate for hot-rodding my engine?
John Forcier
Old 10-27-2003, 03:06 PM
drag racing the short bus
dd74's Avatar
Are the Euro 9.8:1 3.0 pistons listed on the Pelican Parts website compatible with CIS or Webers or both?
This would be part # 99-0174-916.
Thanks.
The Terror of Tiny Town
Old 10-27-2003, 11:17 PM
Wayne 962's Avatar
The 3.0 Pistons would be compatible with CIS and Webers. Although, to get max performance out of the Webers, you would want to upgrade to a more agressive cam, which wouldn't be compatible with these pistons.
The CIS 'S' cams would go well with the 911S 2.7 pistons. I have a set of newly reconditioned 911S 1974 cams for sale if you're interested. $495 incl shipping...
-Wayne
Old 10-28-2003, 03:25 AM
i think you mean the MFI version of the 2.7 piston, which has a flatter crown, valve reliefs and the same 8.5 compression. generally used with performance cams and carbs.
206 637 4071
Old 10-28-2003, 07:55 AM
dd74's Avatar
-Wayne
No. My 2.7 is long gone. I have a 3.0. I am looking for pricing on 9.8 pistons and also pistons to push the 3.0 displacement to a 3.2 short stroke, both of which would need to work with Webers and S cams.
Any ideas?
Old 10-28-2003, 08:11 AM
