Bird. It's the word...
Fishcop's Avatar
Thanks Wayne, that's just what I intend to do. I'm just having a bit of trouble locating someone who can re-Nikasil barrels here in Australia.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-09-2003, 03:16 PM
Warren Hall Student
Bobboloo's Avatar
Plating isn't cheap and I wouldn't plate the 2.7 Alusils cylinders unless they were like new. The cylinders tend to wear in an oval pattern. If they show wear I would bore them out to 92mm and then plate them and get a set of 92mm JE's to give you a 2.8L motor. Plating is about $1200 for the set and the pistons are $1000 for a total of about $2200. You might also consider a new set of 2.9L Mahle P+C's for a few hundred more.
The cheapest alternative is a new set of Mahle 2.7RS P+C's. You can pick these up for about $1400.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-10-2003, 02:58 PM
CamB's Avatar
DO IT JOHN! The exchange rate is your friend right now...
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 11-10-2003, 03:53 PM
The 2.7 RS are forged, not cast pistons.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-10-2003, 05:42 PM
Warren Hall Student
Bobboloo's Avatar
That's a good point Ron. Are the 2.7 Euro sets that are forsale these days from people like EBS forged like the original ones?
Bobby
Old 11-10-2003, 05:53 PM
Cool
I can only imagine that they are.
I bought my 2.7 RS forged from EBS in '98 for about $1600US
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-10-2003, 05:58 PM
Fishcop's Avatar
I've noticed a couple of sets on Ebay for around $1700 USD, is this good price, or can I do better?
You're right Cam, 71.43 today
John Forcier
Old 11-10-2003, 07:02 PM
Fishcop's Avatar
You were too fast for me Wayne! Okay I'll test you... What can you do a set of RS P&Cs for?
Cheers
John Forcier
Old 11-10-2003, 07:04 PM
Cool
I mentioned the info as a data point.. I always give PP the 1st shot at my parts, except the wierd ones. I didn't know PP existed in '98..
no dis-respect intended.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-10-2003, 10:29 PM
Author of "101 Projects"
Wayne 962's Avatar
For the BBS, we can offer them on special for $1599. This is brand new, and applies only to the two sets that I have in stock. If you want them, then give Tom a call at 1-888-280-7799x221. This is a below-normal-margin thank you deal to people who have contributed to this forum. This is the forged, Mahle, 1973 911RS 2.7 Piston and Cylinder set.
-Wayne
Old 11-11-2003, 01:31 PM
John
What happened with the 2.4t uprated to S specs and Webers that was for sale? Did you get to look at or drive that motor. I believe that it still for sale.
Old 11-11-2003, 11:24 PM
Fishcop's Avatar
I don't believe there was anything wrong with the 2.4, It was just that I found a complete 2.7 for half the asking price of the 2.4
ber911????
John Forcier
Old 11-13-2003, 02:09 AM
Fishcop's Avatar
Wayne, thanks for getting back to me on the RS pistons. I will make some enquiries in relation to additional import costs. What do you think the shipping weight/price would be to Australia? I'd phone you but you lot are asleep when I'm awake!
John Forcier
Old 11-13-2003, 02:12 AM
Wayne 962's Avatar
Nope, I'm awake. I'm not sure of the shipping costs - where are you located? Probably about $100 or so - we won't ship this Internationally without insuring it...
-Wayne
Old 11-13-2003, 02:57 AM
CamB's Avatar
John
I had a set of P&C DHL'd from California for slightly more than what Wayne quoted (US$128). They arrived in only a few days.
(disclosure: bought before Wayne started stocking the P&C - I would have bought from him, of course)
1975 911S (in bits)
Old 11-13-2003, 12:18 PM
Cool
I was using the 2.7 RS 8.5:1 with stock CIS.
and not a problem with getting a good mixture and smog numbers were great.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-13-2003, 01:03 PM
John - Some encouragement for you: I dyno'd my new race motor on Wednesday, the base specs are:
2.7 litre 7R case - hpc coated
Carrera RS ports/valves (with some massaging) (36/38 I think?)
10.5:1 ARIAS pistons - short skirt, hpc coated
GE80 cams
Early heat exch's
Single big outlet monty exh
40mm Webers
Made 228hp basically untuned and running rich.
Now just have to sort out the MFI pump, finish the dual distr and connect up the second set of plugs...hoping for 250hp
Cheers - Ryan
ps: the GE80 cams are great - no probs at all driving on the street
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 11-13-2003, 07:05 PM
Fishcop's Avatar
Ryan
Your engine sounds quite similar to what I'm building:
7R case
S cams
Webers (34 venturis)
RS P&Cs (8.5:1)... or something similar
Early exhaust (with the heat exchangers removed)
Big Mili Miglia silencer (single out)
Heads are standard 2.7 with some mild porting
I'm chasing 200 (reliable) hp
What's the story with the HPC coatings and what sort of cost?
John Forcier
Old 11-13-2003, 09:23 PM
