Slumlord
Porsche_monkey's Avatar
Is This a 'Book' Typo?
Page 143 (RHS column, 2/3 of the way down) of Waynes Engine Rebuild Book says
"The gaps in the two compression rings should be located roughly opposite from each other on the piston, and NOT lined up with the piston wrist pin."
With the oil ring gap at the top, and the two compression rings on the sides then they they ARE lined up with the wrist pin aren't they?
Old 11-27-2003, 06:43 AM
No Expert
jgparker's Avatar
The part that confused me was figure 4-7 which actually points at the wrist pin as the correct location for the compression ring gaps. I've heard either way if fine. My Deves rings recommended the 9 o'clock 3 o'clock 12 oclock orientation, so that is what I went with.
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 11-27-2003, 07:22 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Since there are 3 ring gaps to set...I usually put them at 120 deg .
So the oil ring goes at the top...the next is 120 around towards the bottom...and the top is at the other side near the bottom.
This has worked OK for me for a long time.
Bob
Bob Hutson
Old 11-27-2003, 07:30 AM
