Jubbie's Avatar
Question Oil return tubes
Hey Guys,
I am in the middle of rebuilding my 930/02 and have a question.
Half of the oil return tubes are the standard solid ones and half are the factory colapsable ones. Should I go back to the solids or go to the colapsable ones? Are the colapsable ones reusable?
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 09-18-2004, 08:32 AM
Unregistered
sammyg2's Avatar
Yes, the collapable tubes are re-useable if you replace all the o-rings.
Wayne recommends in his book to replace them and go back to the original design, only reason I can think of is to restore originality and to eliminate potential leak points.
On mine I plan to re-use the collapsable tubes with new o-rings, only becaue I am a cheap bastard and they work fine.
Old 09-18-2004, 08:54 AM
Irrationally exuberant
ChrisBennet's Avatar
Speaken as a frugal Yankee I might suggest that new solid ones might be less expensive than you think.
The large O-rings come with the lower gasket set so I won't count those.
New inner O-rings for the collapsible tubes cost 1.50 each (2 per tube) or $12 total.
New solid tubes cost $8.95 or $35.80 total.
So a new set of solid tubes is only $24 more than o-rings for your old collapsible ones.
No drips - priceless.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-18-2004, 07:34 PM
Friend of Warren
When I rebuilt my 3.2 I posed this question to John Walker and he recommended going back to the solid tubes to eliminate another potential source for an oil leak.
Kurt V
Old 09-18-2004, 07:45 PM
