Porsche Crest Tach not working II
After I've located the black/purple wire running from the distributor, to the multi-pin connector, does the black/purple wire then run directly to the transitorized tach, or does an electric sender/unit exist that could be burned out? (1972 911T with 1967 911 engine, Perma Tune and Bosch Blue coil)
Thanks for helping.
Frank in Naples, FL
1972 911T
1983 944
Old 12-02-2003, 04:58 AM
