Sticky question.... i have a 3.0L and $4K. What to do?
Hi guys, a dream situation. I received 4K that wasnt planned.... so i MUST spend it right? on a Porsche related way, right? so....
I have a 1978SC 3.0L, leak-free, strong pullling good but not documented. I dont know if it has been rebuild or not. What should i do?
1) Upgrade de 3.0L
a) supercharged?
b) oversized?
c) SSI, exhaust and the usual way?
2) Sell the 3.0L, go 3.2 or 3.4 or 3.6?
Lemme know your thoughts. Thanks!
PCA Member
2009 Audi A3 2.0 Quattro
1978 911 SC Targa
Old 12-03-2003, 05:20 PM
SSIs and a monty muffler will get you 15+ HP, improve the heating, and make it sound real nice, n'est ce pas?
206 637 4071
Old 12-03-2003, 05:36 PM
Hi John, already have a Bursh exhaust and my heater system goes very well, merci!
I thought of the usual SSI’s set-up, but between the SSI’s set-up and a 3.2 w/Chip, whats best? Thanks!
PCA Member
1978 911 SC Targa
Old 12-03-2003, 05:45 PM
can you get a 3.2 for $4K canadian? not really a huge difference in horsepower between the 3.0 and 3.2, plus 3.2s have valve guide problems, requiring a valve grind, which can cost $3K US. i would keep the 3.0.
206 637 4071
Old 12-03-2003, 06:20 PM
Walker: i would keep the 3.0L
Ok, then what to do with it? Does it worth going the cam way toward the subtle SSI´s upgrade? not too keen opening the case (crank/rods) but could face a cam/head job.
Thanks!
PCA Member
1978 911 SC Targa
Old 12-03-2003, 06:31 PM
HarryD's Avatar
Your engine sounds ok already.
Personally, I would spend the money on suspension improvements and driving school.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-03-2003, 08:11 PM
blau911's Avatar
Farleyd,
Perhaps a nice set of performance cams? I have heard that early 911S cams and especially early 906 cams really perk up a 3.0L engine. Since I am an early 911 enthusiast running Weber carb's on both of my cars, I don't know what you would need to do with your fuel injection system in order to switch to hotter cams?
Old 12-04-2003, 03:12 AM
Friend of Warren
I would go with the SSI's and muffler. The rest will quickly disappear on fixing all the things that need fixed on a 25 year old car. Things like struts, shocks, rubber bushings.
Kurt V
Old 12-04-2003, 06:08 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Blau you can't run cams that wild on a cis car becaust the high over lap cause some reverse pulses, screwing with the fuel metering flap.
I think i posted this before, or it sounds familiar but for that money why not buy one of the cheap turbo bolt on kits. 40-60% increase is some major cojones in that car but not enough to cause other $$$$ mods.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 12-04-2003, 02:14 PM
blau911's Avatar
1fastredsc,
Thanks for the info on hot cams and CIS.
Well, here's another reason to stick with the early 911's: Weber carb's. They allow you do many modifications with your engine, without creating major induction problems.
Old 12-04-2003, 07:50 PM
vash's Avatar
save the money until you really need it.. and you will!
damn sorry guys, my mom got onto my computer. time to change the password.
poof! gone
Old 12-05-2003, 10:11 AM
Now in 993 land ...
aigel's Avatar
Why not sell your engine and get a 3.6? That should be doable for a 4k difference. But of course, you will have to be the one doing the work! 4k is a lot of dough, OTOH, if it comes to messing with the flat 6 it unfortunately isn't that much any more!
I'd stick with SSI and keep the rest for other areas where you might need improvements!
G
81 SC (sold)
Old 12-05-2003, 11:37 PM
