Rebuilt/overhaul 3.6 engine - advice needed
It looks like I have the famous head to cylinder leak on my 91 3.6 engine with about 45k miles on it and it's time to address that. I am in the process of planning what else I should do while I am in there. I don't want to split the case. While I don't want to spend tons of money I still want to do it right. So a 3.8 conversion is probably out of question if the cylinders are still in spec. I would like some feedback from the group:
- Should I replace the rod bolts with ARP or Raceware. Which are better? It seems the Raceware are not stretch bolts while the ARP are. And it can be done through the spiggot holes, right? - Should I replace the head studs with the 993 type, raceware, or ARP or leave them alone? - Should I have the exhaust valve guides done only or both intake and exhaust? - Should I replace the piston rings? - I will use Walt at Competition Engineering to flycut the heads and the cylinders and to machine a groove so that I can use headgaskets? - Tyson suggested to replace the O-rings on the case through bolts. Anything I have forgotten, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
You can easily get close to 300 honest hp w/ stock 3.6 pistons and careful headwork/cams/chip.
Are you sure Competiton Engineering could do something to the cylinders for the head gasket. I always thought they could machine the head and then you had to get the newer style cylinders that accept the head gasket. If they could machine the cylinder some how it sure would be a less expensive alternative to new cylinders.
1990 C4 Cabrio 1983 911SC (RIP) 1997 Expedition EB 2004 EXPLORER ( Momma's Car) Zink Z-12 FV ( sold ) 2005 Cub Cadet 1046 |
I talked to Walt several times. Really nice guy. Yes, he can machine the cylinders too so that I can re-use them if they are in spec.
Ingo
Not that my 1990 C4 has a leak, but that is good to know when rebuild time comes. Do you have a guessitmate for the cylinder and head machining. Just wondering for future planning purposes. PM me if you don't want to post the cost.
alan911sc,
I have my heads and p&c's at the machine shop as I write. I'll give you detailed info once they're done. It should be in a week or two.
John 1997 993 2012 991 |
Definitely will appreciate the feedback. Have a happy holiday season if I don't hear from till then.
