Question Engine dimensions
What are the following 911 engine dimensions:
1. Lenght from gearbox mounting surface to the crank pulley (inc. pulley)?
2. Overall width?
3. Distance from the middle of the crank to the lowest point of the sump?
Who can help me?
Old 12-08-2003, 08:09 AM
neilca's Avatar
I recently measured from the gearbox mount to the front of the fan pulley it was 20.5 inches. I do not have the other dimensions.
Hope that helps,
neilca
Old 12-08-2003, 09:29 AM
Thanks, neilca! Who else can help with other dimensions?
Old 12-09-2003, 04:47 AM
neilca's Avatar
I got the rest of the measurements. 30 inches wide and 8.5 inches from the center of the crank to the bottom of the sump.
Hope that helps,
neilca
Old 12-13-2003, 07:16 AM
Many thanks, neilca! It is huge help for me. Thanks!
Ups i forgot one dimension: from the centre of crank to the top of fan housing. Could you do it for me one more time?
Old 12-15-2003, 02:00 AM
neilca's Avatar
I will be at my shop on Thursday. I will try to remeber to get that dimension.
Old 12-17-2003, 05:20 AM
O.K. I'll wait. Thanks!
Old 12-17-2003, 09:24 AM
neilca's Avatar
The fan I have is a five blade. I measured from the center of the crank to the highest point on the fan and it was......13.5 inches. This is a lot lower than the four cylinder with the 911 fan.
Good luck,
neilca
Old 12-19-2003, 05:11 AM
Many thanks one more time!
Old 12-22-2003, 04:50 AM
