What are the following 911 engine dimensions:
1. Lenght from gearbox mounting surface to the crank pulley (inc. pulley)? 2. Overall width? 3. Distance from the middle of the crank to the lowest point of the sump? Who can help me? |
I recently measured from the gearbox mount to the front of the fan pulley it was 20.5 inches. I do not have the other dimensions.
Hope that helps, neilca |
Thanks, neilca! Who else can help with other dimensions?
I got the rest of the measurements. 30 inches wide and 8.5 inches from the center of the crank to the bottom of the sump.
Many thanks, neilca! It is huge help for me. Thanks!
Ups i forgot one dimension: from the centre of crank to the top of fan housing. Could you do it for me one more time? Last edited by Yaninnya; 12-15-2003 at 04:50 AM.. |
I will be at my shop on Thursday. I will try to remeber to get that dimension.
O.K. I'll wait. Thanks!
The fan I have is a five blade. I measured from the center of the crank to the highest point on the fan and it was......13.5 inches. This is a lot lower than the four cylinder with the 911 fan.
Good luck, neilca |
Many thanks one more time!
