Porsche Crest Bosch Twin Plug caps and rotors
Based on a measage thread in this forum March 25th 2003, I was wondering if there is significant interest in remanufactured Bosch twin plug caps and rotors, and what would people be willing to pay to get one ? Also, would there be any copyright implications if one was going to start remanufacturing something of this nature ?? Advice, comments please......
Old 12-24-2003, 06:18 PM
89turbocabmike's Avatar
There is already someone manufacturing these caps for Andial. I can't remember his handle, but he posts here on the board. Of course competition would make the prices more reasonable! I'm currently shopping for twin-plug ignition solution to my future upgrade.
Old 12-24-2003, 06:31 PM
Super Moderator
cstreit's Avatar
This is a capitol idea!
There are a ton of twin-plug vintage cars who could benefit from this, simply because the other alternatives are not period correct. If you could get the price down to (or under) the cost of other twin-plug solutions (Electromotive, modified 964 setups) which typically run $1500 or more, I think you'd be in good shape.
I would have purchased this over the other solutions if it were available to me.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-27-2003, 08:39 AM
Chris:
Indeed, these caps and rotors are available once again. Not cheap but, available.
I've got as many as you want,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-27-2003, 08:39 PM
rs911t's Avatar
Everyone talks only about the caps and rotors. Does this mean they work with a standard early distributor?
Steve, what's your idea of "not cheap"?
Greg
Old 12-28-2003, 06:44 AM
Super Moderator
cstreit's Avatar
Steve,
I'd also like to know... Are those available for standard distributor setups, or are they using a 'special' dizzy? If stock, does the distributor require modification?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-28-2003, 08:21 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Chris,
According to the BA book you can have your SC distributor converted to take a twin plug rotor and cap
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-28-2003, 09:04 AM
The Bosch RSR caps and rotors were specifically made for the larger Bosch, 917, RSR, and 935 distributors.
We convert late model Bosch breakerless distributors with a special billet plate to accept the RSR cap and modify the shaft to accept the RSR rotor.
You may contact me directly for pricing.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-28-2003, 12:14 PM
Roamer's Avatar
Steve, or anyone else, can these 12 plug caps and rotors be used with a stock Carrera 3.2 dizzy? If so, what is involved in the conversion?
I would prefer a single distributor over the twin 964 style.
Old 12-29-2003, 07:38 AM
Roamer:
Your Carrera distributor can be used for this conversion. Depending on what engine management you use, you might need an SC dizzy for a donor.
The Carrera one has no trigger assembly inside and that needs to be added when not using crank position timing.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-29-2003, 08:00 PM
Roamer's Avatar
Gotcha, thanks Steve. I am still trying to figure out my engine management solution so I will reach out to you when I do.
Thanks again.
Old 12-30-2003, 06:15 AM
