Porsche Crest Best Way to Install P/C's
Say Gang,.. well finally able to install my PC's on a 81' 3.0...what is the best way .Piston into cylinder then to rod,..or piston on rod and then the cylinder,. I have a bit of trouble lineing up the pin with the rod once the cylinder is installed on the piston,..could the second way be the best ?????????????? Thanks Frank
Old 01-16-2004, 08:12 PM
anh911's Avatar
I prefer to install pistons into the cyl then onto rod. This way I can use a full ring compressor. Other people prefer to use the pliers type compressors and install the pistons onto the rods first. Whichever you use don't forget the cylinder sealing rings and circlips on both sides of the wristpins. Follow Wayne's suggestion and use plastic wrap over the openings in the block so you don't drop a clip in there.
anh911
'94 Dakota - Meh
'98 Moto Guzzi - woo hoo
911; XJS; Islander 36; All Sold
'97 YZF1000RJ - Totaled (Not by me)
Old 01-16-2004, 11:23 PM
I understand why,..But its harder to line up the pin..I think I'll try both ways??? Thanks Frank
Old 01-17-2004, 06:56 AM
Senior Member
Doug Zielke's Avatar
The key to putting the cylinders over pistons/rings already on the rods, is a quality ring compressor. I have the Snap-on plier/band type, and it works perfectly. On all the engines I have worked on, I have never put the piston inside the cylinder first, so I don't know how that would work.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 01-17-2004, 09:47 AM
to ease getting the pin started in the rod, tap the pin thru the piston so about 1/16" of the pin protrudes thru the inside of the piston. just enough to still allow the piston to go over the rod. then start the pin into the rod and tap it thru.
206 637 4071
Old 01-17-2004, 10:00 AM
OK Thanks,..here is another Question...is 160 mm or 0.063 too much Deck height on a 81 3.0 at 60 Deg F....Thanks Frank
Old 01-17-2004, 10:51 AM
I just rebuilt my engine and used the piston into the cylinder then onto the rod. Puttinging the clips into the piston to secure the rod to the piston was a bear. Took a lot of playing to figure out how to do it efficiently. If I had the right tool, I would have preferred to install the piston onto the rod, then install the cylinder over the piston. Would have saved a lot of time. Maybe if you have good hand dexterity it would be easier but it was a chore for me.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 01-21-2004, 06:44 AM
Yes Iam doing it the same way...Thanks Frank
Old 01-21-2004, 09:40 AM
Irrationally exuberant
ChrisBennet's Avatar
If you are installing the piston in the cylinder first, it's a lot easier to put one of the wrist pin clips in while the piston is on the bench. Just be aware of what side to you are going to need to access when installing them.
I've done it both ways. I think Wayne makes a very good point. For me, the thick JE wrist pin clips are such a pain to install (I find it almost impossible) that I have to put the pistons on the rods first. For "normal" wrist pin clips I think I'll switch to to piston-in-cylinder-first method from now on.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-21-2004, 11:19 AM
Super Moderator
cstreit's Avatar
I like putting the piston in the cylinder first. I feel like I can align it better and reduce the risk of breaking a ring.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-21-2004, 11:27 AM
