magic930's Avatar
Flywheel wornout?
Specs in Wayne's book say that the 930 flywheel for the turbo should be min of 9.9mm. Mine is at 10.59, how many miles would I get from this or should I just replace it.?
Also it is not the stock flywheel but appears to be a "Patrick" brand.
Old 01-19-2004, 10:04 PM
magic930's Avatar
Thanks Wayne, how important is having it "resurfaced"
Old 01-20-2004, 03:54 PM
Author of "101 Projects"
Wayne 962's Avatar
A loaded question - I'm not sure I can answer this one. If it's very warped, then yes, it needs to be resurfaced. If not, then it will be okay. It's probably best to have a machine shop check it out...
-Wayne
Old 01-20-2004, 10:45 PM
