Doug E's Avatar
Final Stages: 2 Urgent Questions
OK, it is 1am here and I'm just now coming in from the garage so please bear with me ...
In putting my engine back together I realize there are 2 key digital pictures I forgot to take:
1) the wires connected to the starter
2) the spring on the accelerator linkage
Can somebody please verify which wires go to which post on the starter (mine has 3: large red, yellow and yellow/blue).
Can somebody please post a picture or describe where the other end of the spring on the accelerator linkage is connected under the CIS? I know one end goes to the plate/linkage but I can't see where the other end goes.
Car is an '81 3.0l SC.
I'm going to search the archives tomorrow but I just don't have the energy to do so now.
TIA.
Doug
'81 SC Coupe
Old 01-29-2004, 10:05 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Doug,
Here is a pic of my throtle linkage and spring. I'm not sure if its the same since my car is a '78SC.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 01-30-2004, 12:45 AM
Super Moderator
cstreit's Avatar
I don't have a picture, but you should have markings on the posts...
1. Red goes to b+
2. Blue goes to d+
Someone else should post the yellow, I can't remember just now...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-30-2004, 06:42 AM
Senior Member
ohecht's Avatar
I think my starter wires have two different diameter wire lugs and bolts, so they are hard to put on backwards.
Olivier
Olivier Hecht
1982 911SC
Old 01-30-2004, 01:42 PM
Doug E's Avatar
Thanks for the help and suggestions.
I'll check on the starter pics but here's the spring I was referring to:
BTW, this picture is from the disassembly and not after all my hard work
I've got a clearer head now so I'm going out to take another look ...
Doug
'81 SC Coupe
Old 01-30-2004, 06:39 PM
For that last spring look for an anchorage eye (hole) on a tab on one of the intake runners. Cheers, Jim
Old 01-31-2004, 07:02 PM
Senior Member
ohecht's Avatar
My 82 does not have that spring at all. There is the hole on the linkage, but nothing on the intake runners nearby.
Do all engines have it, and is it critical? I have never noticed any problems with only the spring on the TB itself.
Does anyone have a picture of where the other end connects?
Olivier
Olivier Hecht
1982 911SC
Old 01-31-2004, 08:50 PM
