Closed Thread
Schuey's Avatar
my 3.0
what would be the benefits of going with a Mahle 3.2 piston/cyl set (93010398910) on the my 3.0 case? with 10.3:1 compression...
what else would I need to do?
I have a chance at a deal on a like new set (NOS) for $1500 is this a good deal?
1992 964 C4 Coupe (black/black)
1982 911SC Coupe (lt blue met/black)
1965 Mustang Fastback (black/black)
Old 02-03-2004, 02:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #1 (permalink)
Super Moderator
cstreit's Avatar
Schuey...
1. More torque and HP because of the displacement.
2. More torque because of the compression ratio.
THe 3.2 used no sealing ring on the heads. THe 3.0L did. Not sure which kind of cylinder you have, but I think it's okay either way.
10.3:1 is really pushing it with street gas and a single plug motor. Get a tank of bad gas and you will likely see detonation. I would either twin-plug it or run 95-97 octane to be safe, particularly in hot weather.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-03-2004, 06:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #2 (permalink)
curlesw's Avatar
I gotta ask, why does hot weather matter? It's just not obvious to me, thanks.
Wayne C.
83 SC
Old 02-04-2004, 09:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #3 (permalink)
Unregistered
sammyg2's Avatar
One of the factors in pre-detonation is combustion temperature. Raise the ambient air temperature 30 degrees, the combustion temperature will likely climb more than 30 degrees due to warmer air charge and less efficient cooling. On a marginal engine or marginal fuel, that might put you over the edge.
Old 02-05-2004, 12:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #4 (permalink)
curlesw's Avatar
Makes sense, thanks.
Wayne C.
83 SC
Old 02-05-2004, 07:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #5 (permalink)
Closed Thread
