LateApex's Avatar
Send a message via AIM to LateApex
Newbie engine builder question
Hi all,
I have a 2.2S engine sitting in my garage/shop. It came out of a 911 race car with under 8 hours on it after a rebuild. Well, since it was swapped out for a 2.7, I have this engine ready to install in my car.
So, I'm new to 911 engines, and this one is missing quite a few parts, ie fan, alternator, fan shroud, misc sheet metal(?), and most important, carbs.
What carbs should I use? I will probably get some used ones and rebuild them myself. what should I be looking for? I found some zenith carbs in the classifieds for a good deal. What about webers?
This will be going in my 914 race car. Thanks!
Rent your Spec Miatas at
www.2020motorsport.com
73 2.0L Project 914-6 PCA club racer
95 993C2 Grand Prix White
Old 02-05-2004, 12:24 PM
Author of "101 Projects"
Wayne 962's Avatar
Webers are basically the standard these days. I don't think they used Zeniths on the 2.2S, althought I'd have to check to make sure. It's easier to find the proper jets and parts for the Webers to set them up for your 'S' engine these days...
-Wayne
Old 02-05-2004, 12:33 PM
I think your engine had MFI. I'd go with wayne on webers though. Safe bet. Another thought are the new FI systems out there for older engines that are completely progrmable and will cost less than a new set of webers.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 02-10-2004, 05:51 PM
Wayne 962's Avatar
Slightly misleading. First of all, you can't get new Webers. You may be referring to PMO carbs? Even with the fuel injection systems, you have to get yourself some throttle bodies which are not cheap either...
-Wayne
Old 02-11-2004, 02:13 AM
Yes, I was refering to PMOs. I believe they purchased either the rights or pattents to the weber IDAs and only that cab as weber still manufactures carbs. Also, at 2k+ the other systems can be cheaper (some include the throttle bodies) and should provide better hp, fuel economy and more reliable to boot!
Old 02-11-2004, 09:03 AM
Home of the Whopper
You can modify Zeniths to work on a 2.2S. PMO's or Webers would be a lot easier to source parts for though. MFI was stock on the 2.2S, but it's difficult (impossible?) to tune the MFI in a 914 unless the cars been cut a little bit. You could always bench tune the engine then just put it in. Either way, the 2.2S will be a blast to drive.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 02-11-2004, 09:58 AM
LateApex's Avatar
thanks guys. you guys are making me excited. But I have to get up off my @ss and start working on the car some more to prep for the engine install.
Old 02-11-2004, 11:08 AM
Wayne 962's Avatar
With all due respect, my BS meter is pegging. Back up what you are saying. First of all, Richard Parr's design of the PMO carburetor is a new design, loosely based on the Weber design. I know of no rights or "patents" that Richard acquired from Weber (which is now owned by another carburetor company).
On the EFI - show me a system that includes the throttle boddies for just over $2K. Post the URL here.
-Wayne
Old 02-11-2004, 03:52 PM
Licensed User
Shuie's Avatar
LateApex, sent you a PM on a Weber setup
Old 02-11-2004, 05:27 PM
