Banned
snowman's Avatar
Understood. Unfortunately if you happen to have an incompetent mechanic and he screwed up your engine, you are most likely screwed as well. Competent mechanics make mistakes, but fix them. Competent mechanics tend to listen to suggestions as well, especially if they are not certain of what went wrong. Incompetent ones tend to blame someone else, never listen, and sometimes don't care either. If you are unfortunate enough to have found a really bad one, the only recourse is usually legal. and then it may only be wishfull thinking that they will be able to pay for their incompetence. The only way to avoid getting one is to do all the normal stuff, referances,,, and even then some good ones have been known to fall on their head and start to do bad work.
Old 02-15-2004, 07:39 PM
TSNAPCRACKLEPOP's Avatar
would an xray of the parts on a rebuild help, especially pistons?
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 02-21-2004, 04:34 PM
Cool
a magnaflux of the throw out brg fork, before re-install, isn't a bad idea
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-21-2004, 06:00 PM
