Author of "101 Projects"
Yes, but if the mechanic doesn't know what happened, then there is a likelihood that it may happen again...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Banned
Understood. Unfortunately if you happen to have an incompetent mechanic and he screwed up your engine, you are most likely screwed as well. Competent mechanics make mistakes, but fix them. Competent mechanics tend to listen to suggestions as well, especially if they are not certain of what went wrong. Incompetent ones tend to blame someone else, never listen, and sometimes don't care either. If you are unfortunate enough to have found a really bad one, the only recourse is usually legal. and then it may only be wishfull thinking that they will be able to pay for their incompetence. The only way to avoid getting one is to do all the normal stuff, referances,,, and even then some good ones have been known to fall on their head and start to do bad work.
would an xray of the parts on a rebuild help, especially pistons?
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
![]() Quote:
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Hmm, if one piston failed, then they should all be carefully inspected, perhaps magnafluxed, as suggested.
-Wayne
-Wayne
Thread Tools | |
Rate This Thread | |
