Nathan M's Avatar
Question Master link timing chains
I'm at the point of fitting my new chains. The old ones appeared OK but the low cost of new ones tempted me into replacing them whilst the motor is in bits. I purchased the master link ones as I've not split the case but there are no instructions I've done a search on here but can't really find anything. Are there any things to be aware of? Which way do should the open end of the link point? Should I secure the circlips with any particular compound (Loctite or something?) The chains are from the same manufacturer as the OE ones.
3.2 Coupe
Old 02-12-2004, 04:03 PM
Bill Verburg's Avatar
Closed end goes in the direction of chain travel, make sure the clips are seated, make sure the sprockets are aligned & parallel, check chain ramps(5 black 911.105.222.06 and 1 brown 911.105.222.05 on the bottom right), check sprockets for wear(hooked appearance of the teeth)
Bill Verburg
Old 02-12-2004, 07:04 PM
vash's Avatar
how do you "break" the old chain?
poof! gone
Old 02-14-2004, 12:35 AM
There's a little tool called a chain breaker, which pops the rivet out
Bill Verburg
Old 02-14-2004, 05:33 AM
vash's Avatar
ah, just like a motorcycle chain tool. thanks bill.
cliff
poof! gone
Old 02-14-2004, 10:34 AM
Nathan M's Avatar
Well, I've done it now and simply used an angle grinder on each side of one of the pins and it punched straight out. I connected the new chain to the old one to wind it round. Very straightforward really, just hope those circlips hold out!
3.2 Coupe
Old 02-15-2004, 01:36 AM
Author of "101 Projects"
Wayne 962's Avatar
Make sure you don't get grit in your engine when grinding!
-Wayne
Old 02-15-2004, 02:41 PM
Nathan M's Avatar
I actually wrapped the whole engine in polythene, and cut a small slit in each side to pull the chain through while grinding. It only needed a couple of seconds on each side, to my surprise, but worked a treat!
3.2 Coupe
Old 02-16-2004, 12:28 AM
