I'm at the point of fitting my new chains. The old ones appeared OK but the low cost of new ones tempted me into replacing them whilst the motor is in bits. I purchased the master link ones as I've not split the case but there are no instructions
I've done a search on here but can't really find anything. Are there any things to be aware of? Which way do should the open end of the link point? Should I secure the circlips with any particular compound (Loctite or something?) The chains are from the same manufacturer as the OE ones.Thanks
3.2 Coupe |
Closed end goes in the direction of chain travel, make sure the clips are seated, make sure the sprockets are aligned & parallel, check chain ramps(5 black 911.105.222.06 and 1 brown 911.105.222.05 on the bottom right), check sprockets for wear(hooked appearance of the teeth)
how do you "break" the old chain?
poof! gone |
There's a little tool called a chain breaker, which pops the rivet out
ah, just like a motorcycle chain tool. thanks bill.
cliff
poof! gone |
Well, I've done it now and simply used an angle grinder on each side of one of the pins and it punched straight out. I connected the new chain to the old one to wind it round. Very straightforward really, just hope those circlips hold out!
3.2 Coupe |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I actually wrapped the whole engine in polythene, and cut a small slit in each side to pull the chain through while grinding. It only needed a couple of seconds on each side, to my surprise, but worked a treat!
3.2 Coupe |
