Advancement changes in a 3.2 Motronic going to twin plug
I am in the midst of a rebuild and am checking with Steve W the chip maker for suggested advancement changes when going to twin plugging. No, I am not doing the rebuild. I have a trusted mechanic doing the work. He generally recommends an 8 degree retardation in spark for non motronic cars. Any other parameters needed to determine the change needed. The car had bad guide valves, blown clutch and is now changing to a 3.4. Thanks in advance. And again, without speaking directly to my mech, I can entertain some technical questions, (have both Waynes book, Bentley, and Haynes).
Old 02-11-2004, 03:59 PM
Super Moderator
cstreit's Avatar
I'm not sure if this is a question or a comment, but I think the standard retard for twin plug is more like 6 degrees...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-11-2004, 05:19 PM
Author of "101 Projects"
Wayne 962's Avatar
From the book:
"Most twin-plug engines will achieve their peak horsepower output at about 23-24 degrees of total advance, compared with the typical 30 to 35 degrees required for single-plugged engines."
-Wayne
Old 02-15-2004, 01:51 PM
