electrical connectors
Doing a topend on an SC. The previous owner managed to break a couple of the clip style plactic connectors and held them together with bread ties. I now need to locate a source for them. I would hate to have to replace the whole engine harness for this. Any suggestions?
Look close on the connector and see if you can find the manufacturer's name molded into the connector. Then just search the web...
Good luck, Arnie |
These are probably Bosch type connectors, same as on most Bosche style fuel injectors and available at most auto parts stores.
David |
I would check AMP. I think they make most of the connectors for bosch.
Thanks, Arnie |
Author of "101 Projects"
Very common - you should have no problem at most auto parts stores...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne and everyone. Do you think that there will be a choice of colors?
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
