cam housing
I have wayne's book but it doesn't cover dealing with the different type of cam nt/assembly I have (3.0). I have the nut off but am having difficulty getting the gasket? undrneath off so I can remove the housing.
Old 03-06-2004, 06:30 PM
Irrationally exuberant
ChrisBennet's Avatar
Are you asking about the round plate with 3 holes in it behind the sprocket? That plate is held in there by a large O-ring. They'll pop out with a little careful pulling in the screw holes. I think you can use the cam to pop it out also.
-Chris
EDIT: Check out this thread
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-07-2004, 04:47 AM
There is a key on the cam holing the thing together and I don't want to break anything. Nothing I have read shows this or talks about how to deeal with it.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 03-07-2004, 03:00 PM
The woodruff key must be removed first. I put a rag in the left chainbox or tip the motor such that if I drop the key it doesn't fall into the motor.
-Chris
Old 03-07-2004, 03:48 PM
Wayne, it is a woodruff key. I never saw it mentioned but, I hope to get it out. Believe it or not, it diasassembeled that entire side with the cam still in the box.
Old 03-08-2004, 06:38 AM
dtw dtw is offline
GAFB
You are having trouble with the woodruff key? Just stick a small screwdriver against it and tap it out with a hammer...
Several BMWs
Old 03-08-2004, 07:18 AM
Where do you put the screwdriver (flathead I am supposing)?
Old 03-08-2004, 08:42 PM
Super Moderator
cstreit's Avatar
RIght up against where the key sticks out of the cam. Make SURE that you put a rag near the chain area so it doesn't go into the motor!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-08-2004, 09:03 PM
