alusil or nicasil
Pulled my heads off and now I am trying to figure out what I have alusil or nicasil. For my 3.0 I know it could come with either but I don't see any marks indicating which. How can I tell.
go get a magnet off of you refrigerator and see if it sticks to the cylinder wall. if it does it's nikasil if it don't it's alusil.
big AL '77 911 |
I guess I am SOL. The magnet didn't stick.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
Who is John Galt?
I wouldn't cry yet. We in the "re-ring alusils" thread have copied a procedure for refinishing the cylinder wall at home for not much money. Read the thread and PM me if you have questions.
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
Mark,
Today I got an e-mail from a Pelican about his cylinder leak test yesterday. This is a ‘72T that we built as a 2.8S with Nikasil 92 mm RSR P&Cs in 1974. Here are yesterdays measurements: #1 - 3.5 % #6 - 2.0 % #2 - 4.0 % #4 - 2.0 % #3 - 4.5 % #5 - 4.0 % Nikasils are amazing! I expect the numbers will be all 2% or so when measured just off the track in a few weeks and not just street driving this past fall. Nuff said! BTW, the head nuts all took torque (but turned a little) and the case hasn’t been split since ’74. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
You can have your Alusil cylinders re-coated with Nikasil. There is a "camp" that prefers the Alusil over the Nikasil. Check the threads.
Rick '78 930 |
Who is John Galt?
It's not a preference of alusil, it's a preference of money. Not everybody is keen to adding 3k to an engine rebuild.
But now that you mention it, why doesn't any current engine manufacturer use nikasil?
Senior Member
But many current m/c and p/w motors have Nikasil bores. And what about light aircraft?
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Biral
My cylinders are Biral.. Can they too be coated with Nikasil?
Senior Member
I checked my oil this morning for the first time in several weeks. It was about a quart low. In about 3000 miles. Most of that quart leaked out between the right side chain housing and the cam housing. In other words, I'm not sure my engine is even burning the air-cooled "minimum" amount of oil. All evidence, including the butt dyno, suggest these ring are air tight. They were replaced at 182K miles, about 50K miles ago. The Alusil cylinders were simply reused. So to those who think their new Nikasils work better than my old Alusils, I say "Bring it on." I'll bet my leakdown numbers are similar to those posted above.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Did you replace the rings because you had to or though it was a good idea?
Birals are very different. They're cast iron cylinders with Al. fins. They function exactly the same as Chevy cylinders. Nikasil and Alusil are Al with a special coating on them for wear.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Who is John Galt?
That's great superman. So far, in the first 300 miles since my rebuild, the engine has burned 8 oz of oil. It had 115k miles, the rings were replaced because the valve guides were shot and I decided to rebuild the whole engine. Comp before teardown was between 150 and 155 for all cylinders.
Yeah, I know they're junk. Send me your old ones.
AHH.. that I don't know I guess the real question is how thin can you make the Al cylinders before you run into problems and then how thick is the Al exterior of the Biral cylinders.
I'm not sure why you want to coat the iron part of the cylinder since it makes a good wear surface. Just some musings by an amatuer
Carrera Gt
Just read the other day that the Carrera Gt is using Nikasil Cylinders in the V10. Not sure of the exact specifics.
You can nikasil cast iron. Done it before for rare or NLA cylinders for vintage guys. Reduces friction (= free horsepower) and gives you a much better wear surface. Nascar guys use nikasil on their iron blocks for that reason.
Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
I'm pleased to hear that.
The disadvantage of the Mahle-Nikasil ones is that, due to lack of steel, they have different expanding properties hence the need of dreaded dilavar studs to match. So "modified" Mahle-Birals, IMHO, would be a better solution as steel studs can still be used on them. Of course this type of mod can only be done on 2.4 or lower. Right? BTW, how thick is the cast iron wall of the Mahle-Biral? And how thick of nikasil lining would be rquired? (what was the lining thickness of the 2.7?) The 2.2 & 2.4 Mahle replacements of today which are nikasil, are they of the exact same construction as the original 2.7? Sorry for so many questions.. tahnks Last edited by blue72s; 03-09-2004 at 06:58 AM.. |
The nikasil plating can be as little at .004" on diameter or in excess of .015" on diameter. For example, i've taken a stock bore 356 cylinder that was wiped out from a grenaded piston and have been able to overbore and replate to factory size, better than new.
Nickies cylinders in bore sizes from 84-86+ for the 2.2/2.4 and 89-92+ are fully finned and have provisions for oe sealing rings. Nickies in bore sizes 95-98+ are also fully finned, based on 3.0 KS alusils / 3.2 Mahles, not the half-finned turbo cylinders and do not use the sealing ring, per the design on the 3.2 mahle. Rather there is a taper on the sealing surface that causes a gradient in clamping loads, thus forming a carbon seal at breaking. Custom piston combinations with Nickies will be courtesy of Pelican Parts and will be available in kit form through the rebuild wizard hopefully sometime in the near future. Call Eugene for more details. For those who don't know what we're talking about: Fin shot of mahle vs. Nickies Photos of a 92mm Nickies cylinder for 2.8 911: http://www.lnengineering.com/gallery/Porsche%20911%202.2%202.4%202.7%202.8%20Nickies/Final%20Production%20Demo/index.html Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
How much does this run? ($)
