torque specs Nm vs. ft. lbs.
so I'm torqing my case together for the 3rd time tonight, I think this may be the last time!
I'm looking at my torque wrench and I notice something odd. all along I've been using the Nm torque values from the book, however this time I noticed the ft-lb value and it stuck in my head. So as I'm torqing my case nut to 35Nm, i notice it's not even close to the 25.8 ft-lb spec that is listed next to the 35Nm in the book. so...is my torque wrench wrong or the book wrong?
big AL '77 911 Last edited by Alan Cottrill; 03-05-2004 at 08:43 PM.. |
1 Nm equals .7375 ft-lb so 35Nm is equivalent to 25.81 ft-lb. Looks like one of the scales is off on your wrench. Jim
Irrationally exuberant
Is that one wrench with two scales on it? If so, wow, that's really bad! Sears should have a "recall" on that wrench. That evil!
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Looking at the image again; the indicator could also be bent or cocked. Those beam type torque wrenches can be a bit fragile. Cheers, Jim
this one is a brand new 3/8 drive dual sacle wrench. I bought it because the majority of the torque values i'll be using will be in the middle of the scale on this wrench.
well I've been playing with it and looking at the scales real close and I've noticed that the scales catch up with each other in the higher ends of the scales. at 90Nm it lines up a hair past 65 ft-lbs which is correct 90*.7375=66.375 so I started looking real close at the scales. at the low end of the Nm scale it's really bunched up and as it goes higher up the scale the hash marks spread out. the ft.lb marks stay consistant across the scale. so then I got out my old trusty 1/2 drive beam type torque wrench that only shows ft lbs. and went to work on some lug nuts comparing it's readings against my new craftsman. the ft.lb readings on my old wrench were exactly the same as the ft.lb readings on my new wrench when torqing the same lug nut at various torque values. so my conclusion is that the Nm scale on my new wrench is meaningless it was probably added in a half a$$ed attempt to offer more "features" to the consumer.
big AL '77 911 |
now I realize that my rod bolts can't possibly be torqued correctly becuase I was using the Nm scale on this wrench.
would I be out of line to ask my local sears store to buy me a new set of bolts?
big AL '77 911 |
fancytown
You need to see if the Nm scale is correct, or the Ft-lbs scale produces the proper torque. Maybe you are Ok???
all cars sold. |
ARRRG!
I just checked the one I used to build my engine with 1000m ago. And it is wrong too!!! I had an old clicker but didn't want to use it since it was a few years old and had not been calibrated, so I bought the beam one. No I appearently have an engine full of undertorqued nuts/bolts... Where do we sign up for the class action law suit
Current: 07 S4 Avant, 06 Volvo S60R Sold: '74 911, 01 986, 93 Volvo 240 |
