68'911's Avatar
Question un-used pully attached to cam
Alright we were thinking of doing the carrera tensioner upgrade but don't know how they would fit considering this (pully thing?), to be quite honest i don't know what it is or what it is for, cause we can't see that it has ever attached to anything. (we were thinking mabey smog pump at on time?) So i guess first of all: what is this seemingly worthless thing and second is can i remove it in favor of some diff chain housings and what-not? Third i suppose is to be asked only if the second was answerd yes; how is it done?
any help will be greatly appreciated.
-68'911
Old 03-05-2004, 09:09 PM
68'911's Avatar
no one knows?
68' 911
96' Prelude
81' 280ZX Turbo (for sale)
Old 03-06-2004, 08:10 AM
No Expert
jgparker's Avatar
The pully is for an air pump for the 1968 only emissions controls. On my 68, I cut the pully drive off the cam, and replaced the covers with the new ones, wich allowed for the carrera oil fed chain tensionsers. I know of several other people who had the stock 68 cover machined to accept the oil fed tensionser. It really depends on what you goal is with the car, and the amount of work you want to put in. If you want to win pebble beach, you need to keep the pully and add the pump back in. If you want it to look clean, ditch the pully. The pump never did anything for performance, and it is not likley to help much with smog test.
good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 03-06-2004, 08:44 AM
No Expert
jgparker's Avatar
The nice thing about those '68 911L cams is they are actually E-cams, except that the left one has the air-pump take-off. The right one is even the same part number as the E- cam.
Old 03-06-2004, 02:15 PM
68'911's Avatar
Thanks for the info guys, I guess what I do will depend on the money i have lefrt nearing the end of my rebuild. Most likely will ditch the pully.
If the smog pump doesn't cut emissions then why would porsche put it on the engine?, it's not cause it looks good
Old 03-06-2004, 08:32 PM
No Expert
jgparker's Avatar
The air pump adds extra oxygen to the exhaust to help burn off excess hydrocarbons, but without a catalytic converter, it does not work very well. It did help a little, but it was ugly.
Old 03-07-2004, 06:15 AM
Irrationally exuberant
ChrisBennet's Avatar
Wow. I thought '75 was the first year of emmisions controls. I guess you learn sumptin' new every day.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-07-2004, 08:03 AM
ValveFloat's Avatar
This may sound a little ghetto, but I cut the extra length of the cam for the pulley off with a hack saw. Turned out just fine.
Joe
1993 C2
Old 03-10-2004, 02:05 PM
