Webers
What are the differences between Weber 40mm 3C-1 IDA, IDS, and IDT carbs? I'm looking to add Webers to a 3.0SC engine and like the look of the vintage Webers.
I've heard that PMO's may be superior, but what about among early Webers? Is there a preferred carb? And, can the early Webers actually be updated to perform identical to the PMO's?
Thank you,
John
Old 03-08-2004, 08:56 PM
Here's what little I know about the differences:
IDAs - most common
IDS - used on early S engines. They have a high speed enrichment circuit that no other triple throat has. Some say this circuit is not needed and will actually shut it off.
IDT - used on my '69 engine, I noticed a different profile on the idle mixture screws. Less slope than IDA mixture screws. The effect is less idle mixture adjustment per revolution of the screw (emission-related). You can change these for IDA screws.
There are tall secondary venturis available, but don't think they were offered on a stock Weber.
Other than that, I think they are all the same save for the default venturi and jet sizes provided by the factory. Not sure about the other versions on the label in the pic.
Sherwood
Old 03-09-2004, 11:28 AM
Thanks for the info guys.
Old 03-09-2004, 12:19 PM
Grady Clay's Avatar
Guys,
Another subtle difference is the size and location of the “transfer ports” in the side of the body next to the butterfly. This affected the transition from idle circuit to the main mixture circuit and had a large effect on the “just off idle” performance.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-09-2004, 12:54 PM
Grady,
Do you know which one had what?
Sherwood
Old 03-09-2004, 03:11 PM
