126coupe's Avatar
2.5 L Race Photo
Well its ready to go in,
Too bad 2 more weeks before the Fab guy
can take the car. Crap, missing 2 races
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 03-10-2004, 04:02 PM
Bird. It's the word...
Fishcop's Avatar
Mmmmm, pretty!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-10-2004, 04:43 PM
126coupe's Avatar
Thanks Mate
28' Pace Trailer
Old 03-10-2004, 04:44 PM
Bandwidth AbUser
Jim Richards's Avatar
Wow! Did you swiss cheese that crossbar for the motor mounts or does someone sell it that way?
Jim R.
Old 03-10-2004, 04:59 PM
126coupe's Avatar
Fab guy did it. No big deal but we went a little
lite and it twisted a little. put in a gusset and
AOK
28' Pace Trailer
Old 03-10-2004, 05:04 PM
Fishcop's Avatar
Minkoff, where did you get the blanking plate for the L side fan? Been chasing a source for a while.
John Forcier
Old 03-10-2004, 05:07 PM
126coupe's Avatar
Porsche Only part. I got it from Andial
28' Pace Trailer
Old 03-10-2004, 05:10 PM
Navin Johnson
TimT's Avatar
Here in the states heater block offs are available from a number of sources.....
'69 911 GT-5
'75 914 GT-3
and others
Old 03-10-2004, 05:45 PM
Fishcop's Avatar
Thanks Tim.... who?
John Forcier
Old 03-10-2004, 07:56 PM
Navin Johnson
TimT's Avatar
To be PC check pelican,
but I know for a fact that they are available from
GT racing
I think smart racing sells them
The price is kinda ridiculous though about $250 USD for a pair
'69 911 GT-5
'75 914 GT-3
and others
Old 03-11-2004, 05:48 AM
Fishcop's Avatar
Thanks Tim, I did check Pelican but got no result. But "Yowza" they are expensive!
Cheers
John Forcier
Old 03-11-2004, 01:17 PM
That looks cool - what are it's specs and how much power do you expect to get?
Mark
'70 914/6 2.7
'89 S4
914/6 GT (Repro) Tarmac Rally car
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 03-11-2004, 02:00 PM
126coupe's Avatar
2.5 L short stroke, Carillos, Boatailed and polishes case(alum) Mahle P and C(Nickasil), Knifed Crank, Carrera Pump, All sprockets lightened, 10.2:1 compression 911 S Sportcam (webb Cam) EBS valve springs, Titanium Retainers, PMO Carbs 46MM, Dual Fuelpumps, 20 Quart oiling system. Hopefully 210 -230 HP to the rear wheels. The car will weigh 1850-1900 pounds.
28' Pace Trailer
Old 03-11-2004, 02:44 PM
Should be a rocket .
I'm in the early stages of building something similar. Several isiues/questions...
1. I don't see any pressure feeds to the chain tensioners??? or am I going blind?
2. 46mm PMOs? All my calculations indicate 40mm with 36mm venturis to be about on the money. How did you decide on 46mm? - just curious.
3. Where did you get 89mm P&Cs?
4. Such a mild cam?
5. Single plug heads? At 10.2:1, I would have thought twin plugs might be a benefit?
Minkoff, I'm not questioning your build, just curiious as to how you came up with the particular mix of components as I'm in the decision phase myself.
Mark
914/6 2.7
'89 S4
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 03-12-2004, 12:10 AM
126coupe's Avatar
I have had good luck w mechanical tensioners, my German engineer suggested 46MM Carbs, 120/104 cam grind good power band for the tracks I run. 89MM Mahles from Andial bought them 3 years ago. Twin plug will be the next upgrade when I refreshen, but w my crane Hi 6 ignition I get great combustion. 906 CAM...NO power band too high I like my engines to last. Ive run this race car for 5 years, already proven success. Im just moving from a 2.2 to a 2.5 cause my class allows it
28' Pace Trailer
Old 03-12-2004, 06:19 AM
