Just checked mine with this procedure and it was simple! Thanks!
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Could anyone post a pic of a new squirter ? There seems to be a kind of spring/valve mechanism behind.
By the way thanks for your tips. I fought with my squirters a few hours before reading this post. Some open up without pressure others don't. |
Don't fool around...buy Steven Stomski's piston squirter cleaner tool. It will save you hours.
http://www.stomskiracing.com/products.html It's not listed on the above URL but call him and ask for it. Norm
Norm '86 930 AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear) |
Hello, Phillipe.
J'aime vos pissettes d'huile nettoye. Bon chance David |
Wer bremst verliert
I just ran into a problem on a 3.0 case. On previous cases I had them dipped and cleaned and in those cases was able to use the method above with a bit of carb cleaner to get them all spraying nicely. I used a different shop this time and had a hell of a time getting the #5 and #6 squirter to flow. After an entire bottle of cleaner and a bottle of the locktite freeze lube the #6 started behaving. # 5 just wouldnt clear. I was at my wits' end and decided to fish around inside the squirted from the case side with some safety wire. I bent it into a little hook then fed it down from the bearing side. After a little fiddling around down there, the next squirt of cleaner came right through.
I squirted a lot of cleaner and lube through there after and never found any debris. I am assuming the squirters just 'froze' too much for the carb cleaner and penetrants to clear up but was loose enough for the safety wire to jiggle it free. I know you aren't supposed to stick wire down tehre but since the next step was to remove the squirter I gave it a shot and it worked...
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I have for years used safety wire with a bent hook on the end put in a battery operated drill to loosen stubborn squirters with no ill effects. I use the lowest speed on the drill and use carb cleaner while spinning the safety wire very slowly and I have yet to damage a squirter.
aws |
![]() here is how i did it.. same but different. i took some rubber hose, sprayed it with WD-40 and slid in a nice round screwdriver beside it. then added some brake cleaner to the main bearing oiler and then followed with compressed air. once i figured out what i was doing, the others went very fast. [Pics] ![]() ![]() ![]() ![]()
This thread inspired me to make a tool for this task, as I could not find a suitably sized chunk of rubber hose to seal the passage on the 3.6. Seems I could back when I did my 3.2 - maybe the bores are different, maybe I have different hose leftovers on hand.
Some 6mm allthread, a few threaded bits of aluminum, and a bit of 1/4" ID rubber fuel line, did the trick beautifully. I used the knurled aluminum bits because I can, but the concept works just as well with some M6 nuts & washers. I'd use a longer chunk of allthread, hold it with vise grips on the outboard side, and use a deep socket on the inboard side. For the other side, the old standby of vinyl tubing and an inflator sort of worked, but it was a pain in the neck to get it to seat. The 10 degree cone worked well. I drilled the back end .219 and pressed it onto a 1/8NPT x 1/8" nipple so it would screw onto the blow gun.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
How do you proceed if the bearings are still in place?
+1 for the stomski tool. I was surprised and pleased how well it worked.
I was on the fence about getting it because my stomski bill was already so high. But it worked so well that it feels like money well spent. |
I love ingenuity of people who can make their own tools.
I use the stomski one, however it is great for the left side of the case and not so great for the right side.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Nice DIY tool! I make some of my own tools, but for this chore I coughed up the dough for the Stomski tool- it worked so well. Great for cleaning, and for testing. Loaded the tool with solvent, and lubed the o-ring each time.
I set my air press regulator at different pressures to see exactly where the squirter was opening and closing. Closing is important- they aren't supposed to be open during idle, to save system oil pressure. So blasting them with air/solvent without knowing whether or not they are stuck open is only half of the inspection!
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region Last edited by 85RedCarrera; 09-18-2025 at 09:11 AM.. |
