magic930's Avatar
Assembly begins
Starting Friday evening with the rods, torque and undo the ARP rod bolts 3 times at 35lbs...
By Saturday afternoon the case is together with only a few moments of panic...
By Sunday afternoon the head studs are in and the flywheel is torqued down.
Old 03-14-2004, 03:12 PM
Ho Hum 74's Avatar
Very nice. You're further than me. I've only just completed the crank.
One thing though: my ARP guide says 45 lb/ft torque on the rod bolts. Did your guide say 35??
Tristan
Old 03-14-2004, 03:23 PM
magic930's Avatar
My ARP instructions for the rod bolts part 204-6005, Porsche 930 turbo. Clearly says 35lbs 3 times... (loosen tighten etc.)... if not using the stretch gauge method.
Old 03-14-2004, 03:27 PM
Ho Hum 74's Avatar
Mine are going into a 2.7 RS spec engine and are part # 204-6001 which probably explains the difference. Says, "Application Porsche 10mm)
Old 03-14-2004, 04:01 PM
vichang4's Avatar
The 87 930 has 9 mm rod bolts which should be torqued to 35 ft/lbs while using the ARP assembly lube. I did mine 5 times just to make sure. The torque and retorque is to eliminate any new (abnormal) tread to nut friction.
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 03-14-2004, 06:46 PM
Ho Hum 74's Avatar
Hmmm.... a 2.7 has 10mm and a 930 has 9mm? Interesting
Old 03-14-2004, 06:48 PM
