Bird. It's the word...
Screwed up a con-rod
Hi All
Well I've finally begun my rebuild with a start on the crank tonight. All went great until I inspected the final result and noticed one of my rod end caps was around the wrong way... the numbers are on opposite sides as opposed to being lined up together. Everything feels smooth, can I leave it like this or must I do that rod again? Thanks
John Forcier Current: 68L 2.0 Hotrod - build underway |
Irrationally exuberant
You have to flip that cap back the right way. If the rod bolts are stock, you'll need new fasteners for that rod too. :-(
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 03-15-2004 at 06:12 AM.. |
Friend of Warren
What Chris said. And if you are using stock rod bolts and have torqued the bolts down, you are going to have to replace those two bolts. Things could be worse. You could have done what I did a couple of weeks ago and install your rebuilt engine and forget to put the ring gear on the pressure plate!
Kurt V No more Porsches, but a revolving number of motorcycles. |
YOU CANNOT LEAVE IT THAT WAY.
Put it on properly, when that rod was built, or rebuilt if you had them done (If not, then you should have had them rebushed, resized and honed and balanced) the caps were in the proper position, if you flip them around, the parting lines will not match up evenly. |
Thanks guys
You told me what I thought....I'll order two new bolts today.
Author of "101 Projects"
There's a thread with more info on this somewhere in the archives of this forum. Basically said the same thing though...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
