thor's Avatar
Smile bosch ditributor
hello ,
what is the difference between a 2.0E bosch distributor and 2.2S (the RPM only?) ...
can I use mine ((a 2.0E) without any problem or my engine will not run well ?
thanks
Old 03-23-2004, 06:34 AM
Stressed Member
Scott Clarke's Avatar
Thor-
I believe that the only difference is the rotor (and the distributor part number). Get an S rotor and you should be good to go.
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 03-23-2004, 08:09 AM
thor's Avatar
the curve is not different ?
Old 03-23-2004, 08:48 AM
Stressed Member
The curve is the same.
Old 03-23-2004, 10:33 AM
thor's Avatar
thanks a lot Scott
Old 03-24-2004, 12:34 AM
