Bird. It's the word...
Fishcop's Avatar
Fitting Piston Squirters
Any one had to fit thier piston squirters?
I'm wondering if I should use an epoxy or locktite product to hold the replacement squirter in my case. It has a reasonably snug interference fit, but not snug enough to hold it against the 50 odd psi oil pressure.
Advice?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-20-2004, 04:27 PM
Irrationally exuberant
ChrisBennet's Avatar
You "stake" them. Look at the originals and you'll see where a chisel (ish) tool has been used to upset the metal around the squirter to keep it from coming out.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-20-2004, 05:07 PM
Fishcop's Avatar
Excellent!. I did notice that, thanks Chris.
John Forcier
Old 03-20-2004, 06:10 PM
how did you get them out, and what is the part number?
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 03-21-2004, 03:53 AM
Cymru am Byth
carmad's Avatar
I had mine replaced during my engine rebuild. I spoke to several well respected Porsche machine shops and engine rebuilders, and there were several opinions about securing these.
Some just staked them as per the factory. Some just used ultra high strength high temp Loctite, their reasoning being that if you try to re-stake around the edges of the hole, because of the heat cycling the aluminum becomes brittle and is difficult to stake properly.
I ended up doing both so I think I have the bases covered.
To get them out I think you use a 5mm drill to open up the end, then you use a 6mm tap and create a thread, then you should be able to pull them out.
Wayne sells them as oil spray valves I think I payed $27 ea, they come in a couple of sizes.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 03-21-2004, 04:47 AM
thor's Avatar
is it possible to add piston squirters to a 2.0 l engine block ?
Old 03-22-2004, 05:29 AM
Navin Johnson
TimT's Avatar
Yes!
and get the 964 squirters, they move a little bit more oil.
'69 911 GT-5
'75 914 GT-3
and others
Old 03-22-2004, 05:35 AM
thor's Avatar
is there a procedure to do it ? what I need to know for this operation ? thanks
Old 03-22-2004, 05:42 AM
