Webcam 158 grind
What kind of specs does this cam have? Is it viable in a carb street motor w/ 9.8:1 cr? Looks like it may be a bit on the wilder side? Does this cam lose all the torque in favor of high-rev breathability?
thanks.
dave 1973,5 |
Irrationally exuberant
Webcam's web site lists a 158r but not a 158.
I'm probably having another Senior Moment but for some reason that # seems familiar - like they were in my '86 Carrera before I went to 964 cams. I think "158" was stamped on the end of the cams. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 01-10-2005 at 05:08 PM.. |
Navin Johnson
I have the 158 in my 911, its a nice cam
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Thanks Chris.
Tim, Can you give me more details about your engine config?
dave 1973,5 |
If you talk to Webcam let us know what she tells you.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
update: from JD/camgrinder I found out that a 158 is a "hot" SC/CIS cam and 158R is a carb cam.
From *her*, I found out that a 158R is their 2.7S cam with valve lift of .450int and .400exh, for duration .232int and .222exh, between 3.0-3.3mm with .10mm lash Does that make sense?
dave 1973,5 |
I forgot Camgrinder was Webcam, not Elgin. When I called Webcam a few years ago I spoke to a woman.I think the cam timing setting value was the same for the 158 as the stock Carrera cams. -Chris
LOL, no no, Chris, you got it all right. (It didn't come through in the text, but I was actually stressing the fact that it WAS a "her".... caught me by surprise b/c it matched your statement
)So no matter how long ago that was, it's still a "her" (which is a nice thing to hear, kinda like those girls on 5th Gear/Mythbusters )
dave 1973,5 |
Car savvy girls are neat. I was visiting a friend at his auto repair shop this summer. He employed a girl (college student I think) behind the front desk. While I'm waiting for my friend, a customer tells the girl that his BMW trunk lock isn't working right, unlocks after he locks it or something like that. I was so surprised when she started telling him that lock used an electric/pneumatic latch actuator made by such and such and it was also used by Mercedes. I think she even told him what the problem was. I said to her "I'm in love! Can you say pneumatic actuator again?" -Chris
John Dougherty Dougherty Racing Cams |
Doesn't want/need a 3.6L
You probably spoke to Laurie Dunlap over at Web-Cam. She is one of the owners...
Ralph |
Navin Johnson
Its either 9.8 or 9.5:1 cr (Id have too look at my notes) Twin plugged 930 oil pump Ports opened to S+ specs Ti retainers and keepers Aase springs TWM throttle bodies tall PMO manifolds EFI carrera tensioners etc. When I first built the engine I dynoed the car, and with the cam timing I used the torque power fell off at about 6500 rpm. Ive recently done a top end rebuild on the engine and timed the cams so power falls off at about 7000 rpm. Im at work right now, but I have some dyno sheets somewhere This engine is alot of fun in a car that weighs less than 2000#
