thor's Avatar
camshaft
hello ,
could you tell me which kind of camshaft is with this ref : 901 105 110 1R and there is a S stamped on the end .
thanks a lot
Old 04-02-2004, 06:28 AM
Doug Steinel's Avatar
The 1966-68 so-called Solex camshad a right cam with the number:
901.105.110.01
Are you sure about that "1R' part? The list of cam serial numbers in Wayne's book do not have any ending in "1R."
77 911, 3.0L
Old 04-03-2004, 10:31 AM
thor's Avatar
yes I 'm sure and there is no information in the wayne 's book...that s why i asked this question ...
Old 04-05-2004, 12:46 AM
thor's Avatar
nobody
Old 04-06-2004, 01:49 AM
Glenn from Denv's Avatar
Sorry, no real help here except to say that the number that you see on the camshaft is the casting number. This is NOT the part number. You have the same issue with the case itself and the heads. There are probably more examples of this but these are the most common.
_______________
Glenn from Denver
94 964 3.8 RSR
Old 04-06-2004, 06:12 AM
thor's Avatar
are you sure this is not the part number ???? well the only way to know is to measure the lift ...
Old 04-06-2004, 06:20 AM
Definitely sure. I was searching for a 964 RSR head and that search made me intimately aware of the Porsche parts catalog.
Sorry to be the bearer of bad news.
_______________
Glenn from Denver
94 964 3.8 RSR
Old 04-06-2004, 07:11 PM
camgrinder's Avatar
I have seen that casting number more than a few times. If it has an S stamped on the front it is an early S right bank cam.
John Dougherty
Dougherty Racing Cams
Old 04-07-2004, 10:36 PM
thor's Avatar
well It 's stamped "S" and the other one "SE" on the end , then it seems to be S cams ? I will compare with my E cams next week when I will dismount the block.
Old 04-08-2004, 01:21 AM
davidl's Avatar
Hello there.
SE is S Einspritz..ie injection.
kind regards
Old 04-09-2004, 04:41 AM
thor's Avatar
Old 04-09-2004, 06:48 AM
