Ho Hum 74's Avatar
Question What torque value for case through bolts?
Guys, I cannot find the torque values for the case through bolts OR the perimeter nuts in Wayne's book.
What are the correct values?
Thanks as usual.
Tristan
Old 03-26-2004, 05:21 PM
25 and 18 respectively. From the Haynes manual.
Old 03-26-2004, 07:04 PM
No Expert
jgparker's Avatar
It's in appendix A on page 200. 25.8 ft lbs and 18.4 ft lbs. I have a copy of this page taped on the wall next to my bench. Is that a copyright violation? Wayne should sell a laminated version of this page.
Make sure your torque wrench is calibrated, and do not over torque the perimeter nuts on a mag case. You'll never forgive yourself if you pull one of the perimeter studs during assembly. This is the fun part...
Good Luck.
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 03-26-2004, 07:22 PM
Not saying that Wayne's book is inaccurate, but just to be sure, I would back up any spec info with another source. Typos appear in strange places, if the factory can print them, so can others.
Sherwood
Old 03-26-2004, 10:09 PM
Ho Hum 74's Avatar
Thanks all for the input.
Tristan
Old 03-27-2004, 05:42 AM
