Bird. It's the word...
Fishcop's Avatar
Case Sealer
Has anyone tried/used 3M 3Bond for their case? I've been told a few people in my club have been using it with great results.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 04-01-2004, 03:39 PM
Irrationally exuberant
ChrisBennet's Avatar
I've heard of people (Andial on 962's) using it on the cam carriers but not the case.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-01-2004, 08:39 PM
Friend of Warren
I used what Wayne recommends in his book (574? the orange stuff) and it did the job for me on my rebuild.
Kurt V
Old 04-02-2004, 06:14 AM
Here's what Gunnar Racing uses....
Old 04-02-2004, 11:51 AM
Fishcop's Avatar
Wayne's right, my intention wasn't to go over old ground, I'd just never heard of 3Bond.
Chris, funny you brought up Gunnar Racing's preference as I had saved this page for reference myself! Who makes the stuff?
My intention in the absence of any "rave reviews" of another product is to go with the Loctite 574
Cheers
John Forcier
Old 04-03-2004, 01:04 AM
No Expert
jgparker's Avatar
I'd like to point out that the requirements for a case sealant on a race engine with a 20 hour life may be slightly different from the sealant used on a street engine that will go 100K plus miles. I can see how Hylomar would make the next rebuild a little easier. Hylomar and Curl-T are basicly different brands of the similar non-hardening sealant. For the record, I stick with 574.
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 04-03-2004, 06:15 AM
Senior Member
Doug Zielke's Avatar
Re: Case Sealer
John,
Seeing has no one has really answered your question.....
First, I'm sure ThreeBond® is not a 3M product. It can be made in either Japan or USA by the (who else) ThreeBond Co. There are a few different ThreeBond formulas. I'm familiar with the 1104.
ThreeBond 1104 a Hylomar-type product. I did not use it on my 911 engine ( I used the Loctite 574 on the cam towers, mostly because I was given some at no cost and wanted to try it.) I use 1104 on all the air-cooled m/c engine work I do.
It's one of the few sealants I've tried, that will stop the leaks of a 60-ish Triumph or Norton motor. So, it should work well on a Porsche too.
I might add that John Walker likes to use Dirko, another Hylomar-based sealant. So I think it's proven there are other products that will work besides Loctite 574.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-03-2004, 08:08 AM
In reference to the Gunnar pictures of Hylomar. Isn't Hylomar blue? The green in the pictures sure looks like Curil-T doesn't it?
The ThreeBond 1104 stuff is also known as "Yamabond". I'm guessing it was a Yamaha factory sealant at one time.
-Chris
Old 04-03-2004, 08:31 AM
Author of "101 Projects"
Wayne 962's Avatar
JP
I agree 100%. Sealant for racing engines is not the same as sealant for engines that will run 100K miles. I also think that racing engines often leak oil as standard operating procedure?
-Wayne
Old 04-03-2004, 11:16 AM
Fishcop's Avatar
Thanks Doug for the product info... I didn't realise it was a separate brand. I had heard of Yamabond though.
I think I will stick with the 574 on this occassion.
Thanks for all the responses.
John Forcier
Old 04-04-2004, 11:50 PM
