compression increase on 930
i was thinking about a mild compression increase for more low end power whilst rebuilding my 930 engine. what would be a safe increase?
Andy UK
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
7.5:1 is often used number by tuners...up from factory 7.0:1. It all depends on fuel and head design I guess as some 4-valve engines go up to 9.2:1 with 1 bar of boost...
Thank you for your time, |
i wasn't going to change the head design at all, just increase the comp for the better bottom end pull. do you think its worth it?
Yepp...7.0:1 is quite conservative, at least in Europe. If you are planing to use EFI then more so.
7.5:1 and some SC Cams would be nice
![]() If going EFI using Carrera manifolds, go to GT2 EVO CAMs!
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Author of "101 Projects"
Make sure you have access to high octane gas...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
wayne, i can get hold of 97ron in the UK, is that a good enough fuel?
and whats the theory behind having to use high octane due to the increase in comp?
I suggest you read A. Graham Bell's book on Forced Induction.
Wayne, I suggest you carry his books
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Irrationally exuberant
I think if you measure the compression you have now you'll find it is significantly lower than the factory number - like 6.5 instead of 7.0 to 1.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I'm rebuilding my 87 930 with 7.5/1 RUF pistons. They are also 98mm (stock 97mm). Sould be together in a couple of weeks. I'll let you know.
Using the formula ECR= SCR * sq rt [1+ (boost/1)] boost in bars (ie 930 full boost .8 to 1) 7.0 to 1 stock @ 1 bar = 9.9 to 1 effective comp ratio 7.5 to 1 RUF @ 1 bar = 10.6 to 1 effective comp ratio with 10.6 ECR you better run high octane or back off the boost. 7.5 to 1 RUF @ .8 bar = 10.0 to 1 effective comp ratio, very close to stock.
Victor Toce 2000 Boxster S w/ Tequipment exhaust 1993 Spec Miata 87 911 turbo - sold 3.4 RUF pistons and cylinders Euro CIS head |
Victor, You need to calculate intake valve closing point in your effective compression formula. The later you close the valve on the compression stroke the less swept volume you will have for your formula.
Changing from a stock turbo cam to an SC cam closes the valve later thus reducing the effective compression. WydRyd, 7.5-1 works nicely with SC cams.
John Dougherty Dougherty Racing Cams |
You need to run higher octane fuel to prevent detonation that can occur with higher boost pressures...
-Wayne
