adomakin's Avatar
compression increase on 930
i was thinking about a mild compression increase for more low end power whilst rebuilding my 930 engine. what would be a safe increase?
Andy UK
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 04-05-2004, 10:33 AM
beepbeep's Avatar
7.5:1 is often used number by tuners...up from factory 7.0:1. It all depends on fuel and head design I guess as some 4-valve engines go up to 9.2:1 with 1 bar of boost...
Thank you for your time,
Old 04-05-2004, 01:46 PM
adomakin's Avatar
i wasn't going to change the head design at all, just increase the comp for the better bottom end pull. do you think its worth it?
Andy
Old 04-05-2004, 02:02 PM
beepbeep's Avatar
Yepp...7.0:1 is quite conservative, at least in Europe. If you are planing to use EFI then more so.
Old 04-05-2004, 03:16 PM
WydRyd's Avatar
7.5:1 and some SC Cams would be nice
If going EFI using Carrera manifolds, go to GT2 EVO CAMs!
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-05-2004, 09:51 PM
adomakin's Avatar
wayne, i can get hold of 97ron in the UK, is that a good enough fuel?
and whats the theory behind having to use high octane due to the increase in comp?
Andy
Old 04-05-2004, 10:38 PM
David's Avatar
I suggest you read A. Graham Bell's book on Forced Induction.
Wayne, I suggest you carry his books
Old 04-07-2004, 03:55 PM
Irrationally exuberant
ChrisBennet's Avatar
I think if you measure the compression you have now you'll find it is significantly lower than the factory number - like 6.5 instead of 7.0 to 1.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-07-2004, 05:02 PM
vichang4's Avatar
I'm rebuilding my 87 930 with 7.5/1 RUF pistons. They are also 98mm (stock 97mm). Sould be together in a couple of weeks. I'll let you know.
Using the formula ECR= SCR * sq rt [1+ (boost/1)]
boost in bars (ie 930 full boost .8 to 1)
7.0 to 1 stock @ 1 bar = 9.9 to 1 effective comp ratio
7.5 to 1 RUF @ 1 bar = 10.6 to 1 effective comp ratio
with 10.6 ECR you better run high octane or back off the boost.
7.5 to 1 RUF @ .8 bar = 10.0 to 1 effective comp ratio, very close to stock.
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 04-07-2004, 08:39 PM
camgrinder's Avatar
Victor, You need to calculate intake valve closing point in your effective compression formula. The later you close the valve on the compression stroke the less swept volume you will have for your formula.
Changing from a stock turbo cam to an SC cam closes the valve later thus reducing the effective compression.
WydRyd, 7.5-1 works nicely with SC cams.
John Dougherty
Dougherty Racing Cams
Old 04-07-2004, 11:05 PM
vichang4's Avatar
I agree that changing the cam will affect compression ratio. For my rebuild, I'm staying with the stock cam and I'm using the formula to calculate effective compression ratios at different boost pressures and different compression pistons. My conclusion is with the 7.5 to 1 pistons I need to back off of the boost from 1 bar to .8 .
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
Euro CIS head
Old 04-08-2004, 05:51 AM
