Last Century User
I have been talking with one of the suppliers of JE pistons. I am thinking of using some nice 3.2 (no sealing ring) cylinders with JE pistons in my 78 3.0. I am unsure if the condition (120K miles) on the cylinders in the engine but I assume they are either worn or KS (I am 0 for 3 on 3.0 and 3.2 engine I have dissembled recently all worthless KS!).
Anyway, he told me I could use the 3.2 cylinders directly on the 3.0 heads with out modification, he said I might want to surface the 3.0 heads. I though the 3.2 heads were different in that they had a chamfered sealing surface that corresponds to the 3.2 cylinder and that the 3.0 head relied on the sealing ring on the 3.0 cylinder. I know the Max Moritz 3.2 conversion was supposedly a slip in, but I assume the heads were machined? I am thinking to save $$ simply using the 3.2 Malhe cylinders I have with 3.0 specific JEs, (I wont get the displacement bump) will the heads work as he has stated? Thanks! |
Author of "101 Projects"
We are now an authorized dealer for JE pistons - give Eugene a call at 1-888-280-7799x260, he's become an expert on these lately.
The 3.0 and 3.2 cylinders are basically the same, with the exception of that sealing ring. Tthe head mounting surface for the 3.0 / 3.2 are the same, and the differences are in the cylinders. You should have no problem using these cylinders Alusil pistons must be used with Alusil cylinders - Nikasil cylinders must be used with Nikasil pistons - don't interchange them. So, if your cylinders are Nikasil, the JE pistons are a good choice... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Last Century User
Thanks Wayne, love your book, web site!
If my heads are good on my 3.0, do I need to have them resurfaced or will the 3.2 cylinders seal ok (if I decarbon them)? I am nervous about the sealing problems I know the 3.6 had with no seal rings. FYI, looking at the prices yesterday, checked today, big increase! Bummer! Thanks ,David |
Hi David,
I just sent you a PM.
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) |
Re: JE pistons
-Wayne
Deviant
I have been thinking about doing the same thing (3.0 to 3.2). I have been working on my rebuild for several month (as time allows). I recently found that I have Alusil cylinders and a broken conn-rod bolt (bummer).
What do you think about the Perfect Bore cylinders with JE pistons? Are they any better than a Nikasil/JE combo? I could save some money getting a used set of Nikasil but new is nice too...
Tim Looney '82 911 SC - sold.... |
