Hilbilly Deluxe
Every picture tells a story.....
In the beginning....
![]() ![]() ![]() ![]() Ted at German Precision did his magic:
Hilbilly Deluxe
Add 6 of these:
![]() Plus some a big pile of stuff shat out by Wayne's rebuild wizard, some pretty hardware from ARP and a distributor from Steve Weiner, and some chewing gum ![]() Bolt on the heads, some of the ancillary stuff, plus some artwork from Novato, ![]() Put it all together and bolt it in the car: ![]() ![]() Put fire to it the first time Saturday, breakin underway. The details: 82 911SC, 111K miles, rebuilt due to excessive oil consumption. 98MM Mahle Cylinders with RSR Pistons, measured at 9.8:1 CR. Cam reground to 964 profile by Elgin. Twin plug with Rennsport 964 distributor conversion, 2 Bosch CDIs and coils. ARP rod bolts, 993 steel head studs. 915 transaxle freshened by Paul at German Precision, (who has since closed his doors, a huge loss to SF Bay area Porsches and Audis) New Bilstein shocks, sport (rear) and HD (front), Turbo tie rods, 86 Carrera sway bars. Probably some more stuff I can't think of. Huge thanks to Steve Weiner, who spent hours on the phone keeping me pointed in the right direction, Wayne for writing an excellent book, without which I never would have managed this. Ted at German Precision did great machine work, and helped me with CCing the heads/piston domes to measure the CR, and loaned me cam timing tools. No leaks, pulls like a freight train to 4K. Still breaking it in, will post dyno results in a few months when it is ready. Tom (Pretty damn happy....) |
Licensed User
Congrats, that sounds like an awesome motor.
Any advice you can give to someone thinking of building a similar engine? Anything you would have done differently? I sent you a PM with a few more questions. |
Author of "101 Projects"
Weird - why do the spark plug holes look backwards in those pics? Optical illusion?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Irrationally exuberant
The 2nd plug hole is on the other side of the head from the "top" plug so they holes are angled the other way. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Hilbilly Deluxe
Tom |
I would rather be driving
Do tell... Where'd you get the 98mm pistons? I am starting my search. I think I will with a hotter cam since I will run carbs not CIS.
Pretty engine. Now you just need to clean the fan to match the heads and case.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Hilbilly Deluxe
They are listed as 10.3:1 with RSR heads. With my 90cc SC heads they came out to 9.8:1. I measured the dome volume at 37.3cc. Quote:
I forgot to mention, I also added VDO cylinder head temp and volt guages, and clubsport engine mounts. Tom |
It's about time!! Nice job!, why did you decided to ditch the M/M pistons(not that there is anything wrong w/ the RSRs)
Hilbilly Deluxe
Part of the problem is that it was in my in-laws garage. If it was at my house, I could have done a little bit each night when I got home from work. Quote:
The Moritz set came up for sale from a customer of the machine shop, and faced with waiting for a potentially mismatched set, or buying a known complete set I jumped on it. Unfortunately, I didn't do my homework. I had assumed the Moritz pistons were standard Euro 9.8:1 compression. I was wrong. When we measured the dome and calculated the C/R, it came up as just under 9:1. Doh. Looking in the piston chart in Bruce Anderson's book (which I should have done first), I discovered that the M/M sets were only 9.3:1. To compound things, the previous owner had the valve pockets machined a little deeper so he could run a hotter cam with carbs. By this time, the low hour race pistons I had planned the engine around had gone away, sold to someone else. Faced with having a low compression twin plug engine, I called around and found Andial had the RSR set, so I sold the M/M pistons to help pay for them. The funny thing is that this started out as a budget top-end only rebuild, and sort of snowballed out of control. Had the low hour race set come through, the price, plus the added cost of twin plug would have still been less than a new stock set of P&Cs. Tom |
I can't wait for a ride!
What is it about twin-plugging that gives me wood?
Chuck Moreland - elephantracing.com - vonnen.com |
Interesting story
First picture:
Is that a hole in your piston or you are just glad to see me? ![]() Very nice engine, btw.
Thank you for your time, |
-Wayne
Now in 993 land ...
Why did you twin plug? Do your pistons have big enough domes to make it necessary?
Cheers, George |
Hilbilly Deluxe
Wayne, it ended up considerably less than that because I had low mileage Mahle Nikasil 98mm cylinders from the M/M set. All I needed were the pistons. All in all, they ended up costing less than a new stock set. When I sold the M/M pistons, the cylinders only ended up costing $550. Tom |
Hey, Emcon5, how about those dyno numbers you promised?
Dave Flaherty 2000 Porsche 911 |
Hilbilly Deluxe
Probably in the next week or 2.
Tom |
Tom,
Good for you. This is the benefit of twin plug. We are spoiled here in Denver in that we can buy up to 116 octane “street” fuel legally, road tax paid. Will the Pelicans in Bezerkeley (Oakland, Albany) please e-mail me. I need some help with my car at my mom’s house in North Berkeley Hills, up near Tilden Park. Best, Grady gradyclay@hotmail.com Denver, CO
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Hilbilly Deluxe
