I have a call in to my favorite crank grinder,
I will quiz him on this heat treat question. I believe most new cranks are induction hardened. Induction hardening is much faster and easier to control the results.
John Dougherty Dougherty Racing Cams |
Guys,
Thanks for the very informative posts. The people in industry and science can make a great contribution to this Forum. I can’t find my old Machineries Handbook. Exactly what is annealing and quenching? What is the difference between “hardening” and “surface hardening?” I assume the hardening process is just as applicable to cam lobes and journals and rocker arm pads. While I don’t want any of the industry guys to give up trade secrets, I have some generic questions. It seems like the flame method is somewhat like TIG (Tungsten Inert Gas) welding where the atmosphere is critical. With flame hardening what is the composition of the flame? Does the process have to be in a controlled atmosphere? Are there chemicals transferred from the flame or atmosphere that affect the hardening or is it strictly a temperature-time cycle process? Does the entire crank (cam, rocker) have to be heated (or cooled) to some specific temperature before the process begins? How long does it take for a crank to equalize (rest) between processes? Can all the journals be treated at once or is it a one journal per day process? Do some of these processes go further than just hardening the surface of the journals? What is the effect of hardened surfaces on the counterweights, internal passages, etc? Thanks to John at Elgin, this is a very informative page: http://www.nitrex.com/iactivefiles/Nitridingmethods.pdf What are the other hardening processes? Sherwood: What are the chemical hardening processes that have been driven offshore? Are these processes any better than those available in the States? Does anyone know of reliable firms that can perform those tasks in Germany, GB, Canada, Mexico, China, etc? Is there a different process for the 2.0T & 2.2T cast iron cranks from the other forged steel cranks? What does Porsche supply in the current production engines? Is there Factory Service Information (current or archaic) available? Perhaps we should list some of the best re-hardening businesses and the pros & cons of the differing processes. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Grady,
I'm assuming EPA regs are making it difficult for domestic heat treatment using the Tuftriding process. Look at the nitriding chart provided by John to get an idea of the waste products as a result of these processes. Perhaps more current techniques are cleaner. I've noticed several companies in the UK offer the Tuftriding service. You can launch a search in Google to get more info. You might even find some domestic companies still doing this; you could also ask some of the Porsche machine shops who/what they use. There are several surface hardening processes, but all create a hardened surface on the base metal to various depths. You still want a relatively ductile, yet tough interior metal structure. Hardened throughout, the part would be very brittle and would fracture in no time. Sherwood |
Annealing is heating the material up to a specific temp for a period of time so that the material relaxes. It will loose all hardening properties. A forged crank would be annealed after the forging process to relieve internal stress. you would typically rough machined,normalized(heated above the critical temp to gain uniformity), then either flame hardened then finish ground or as John D. has brought up, finish ground then nitrided. Wayne should feel vindicated on the matter of heat treatment when a regrind is done specifically with nitridded cranks.
I will guess that the atmospere is not critical when flame hardening. I saw a history of the beatle on the t.v. . They were flame hardening the mains on a sort of engine lathe. each main had an individual flame pointed at it. It was rotated while it was heated then quenched with oil. Quenching is the temp down past critical leaving the austentite molecules fixed. The process is done until there is sufficient austentite ther to achive the Brinell hardness required. The process was automated and done very quickly. Flame hardening can achieve depths deeper than with nitriding. Keep in mind that you only want a hard surface, when you harden it becomes brittle.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ Last edited by BURN-BROS; 04-24-2004 at 12:07 PM.. |
Here is two more links.
http://www.metaltreaters.com/page3.html Kolene Corp. owns the trademark to the name Tufftriding and from the looks of it may only be able to salt bath nitride now. http://www.kolene.com/applications/sbn.asp
is there some reason that i cannot think of which stops people from cryo treating cranks??
74 911s neverending story. two feet and a jetta for now. |
As far as I know, cryo-treating metal does nothing for surface hardening, which is what you want to achieve on bearing surfaces.
Sherwood |
This is the info I have,
all cranks from Porsche starting with the 356 C engines are tennifer treated. This treatment only goes .003" deep and is lost on the first regrind. I recommend nitriding any Porsche crankshaft that has been ground undersize. I have seen a few Cryogenic treated camshafts and all have been bent over .050". I do not see a benefit on camshafts freezing them. The following link is for Goodson products, they have the chemical to check crankshafts or heat treating. It is called Ni-check. http://www.goodson.com/g5-bin/client.cgi?G5genie=1;G5button=1;search_button=Sear ch;INVOICE_ID=&item=P5013
Thanks John. I will log that info in my peanut.
Aaron
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
cross drilling
hello guys.
I'm grateful for the excellent information posted..thanks. To save us reinventing the wheel, please could some kind soul advise me on the best axis to drill the cross-drillings? On most run rod bearings I have seen, it is the same journal.. that farthest from the ends, which goes. So I was planning to drill through the adjacent main, and one other. But what I'm not sure of is what axis to drill on.. ie oriented to, say no1 crank throw.... and whether to drill through both sides of the journal.. Kind regards to all.. David |
sorry to open an old post. Im curious if the thoughts have changed on regrinding cranks in the last 7 years?
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
If you plan on sending out a crank for re-grind, "ring" the crank first.
You hold the crank on your fingertips on one of the counter weights and strike the crank gently on the outside edge of another counter weight. Do not strike a journal!!! A good crank should ring like a bell. A bad crank will sound dull like a "boink". Fastest way I know to check for cracks. This does not guarantee a non cracked crank, but it has stopped me many times from spending $$$ that I did not have to spend getting a shop to Magna-flux or Dye-pen check a crank. My $.02 Bob
Bob Hutson |
Mark,
You can regrind them, however they must be nitrided to maintain durability. Further, they need to be straightened after that process is completed. The only guy I trust to do this critical job is Armando at Marine Crankshaft in CA. Naturally, one requires oversize bearings and those are not cheap. In many cases, its far less expensive to source a GOOD used standard crank.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Cranks
Chaps,
I am always surprised about the variety of opinion on the subject of 911 cranks and their heat treatment and the variety of solutions that seem to be advised. I have put up a few posts on the subject but it doesn't hurt to repeat some of these comments. I believe that all early cranks were Tenifer treated which is the Trade name of a process known as ferritic nitrocarburising. The sam process is sold in the UK as Tuftriding and in the USA is also known as Melonite. There may be some small differences in chemistry but the basics are all the same. This process was typically carried out in a cyanide bath at around 570 degC. As has been stated the surface layer is very thin being only a few thou so the influence on fatigue life is modest. |
Cranks
Chaps,
I am always surprised about the variety of opinion on the subject of 911 cranks and their heat treatment and the variety of solutions that seem to be advised. I have put up a few posts on the subject but it doesn't hurt to repeat some of these comments. I believe that all early cranks were Tenifer treated which is the Trade name of a process known as ferritic nitrocarburising. The same process is sold in the UK as Tuftriding and in the USA is also known as Melonite. There may be some small differences in chemistry but the basics are all the same. This process was typically carried out in a cyanide bath at around 570 degC. This process also known as Salt Bath or Soft Nitriding and is certainly the poor relation of the genuine Nitriding Process. As has been stated the surface layer of a tuftrided part is very thin being only a few thou so the influence on fatigue life is modest. There are many claims that Tuftriding can add between 20 and 60% to the fatigue life of a component but this statemnt does show a lack of understanding of the nature of the fatigue process. The idea of Nitriding is to introduce surface residual stresses that inhibit the initiation of short fatigue cracks and thus significantly increse the fatigue endurance limit of the component. An increase in life of 20% assumes that the component will fail at some time and cranks need to be designed for an infinite fatigue life. The fact that they do fail in fatige is due to the stoichastic nature of the fatige process or some other manufacturing defect such as too sharp a radius, as has already been mentioned. Nitriding has a much greater and substantial impact on fatigue life than tuftriding will ever manage. The scuff resistance offered by both processes is useful but is not at the heart of the process. I have to say that without deatiled knowledge of the steel used for 911 cranks I wouldn't nitride. Nitriding generally requires a specialised steel with EN40B being a common example but 722M24 and M897M39 are good alternatives. Aerospace materials such as S132 would also be good. Nitriding non-nitriding steels can lead to brittle surfaces which can spall and flake in a very unhelpful manner. I am also concerned to hear that nitriding can cause distortion and bending. Traditional nitriding in a gaseous environment would almost always be carried out with the component being hung and therefore in tension. A typical heat treatment/manufacturing cycle for a nitrided part would be to rough machine - often from a forged blank, harden and temper to say a T condition, and then machine to a reasonably close tolerance. I would then excpect the part to be stabalised at 590 degC to allow stress relief and any movement to occur. the part could then be finish machined and Nitrided at 570dgC with no further distortion. The white layer produced during nitriding would then be removed form the journal surfaces by grinding and this allowance would be made prior to heat treatment. I am intrigued to find that cranks are now being induction hardened as a means of improving fatigue life and I would like to see more detail of how this is carried out as i would be concerned that the steels needed may be OK for normal road engine but coul be limited for high rpm race motors. Certainly a great many road cars now use an Austenitic Spheroidal Graphite cast Iron which has excellent strength ductility and fatigue life. This material was developed at BCIRA in the UK and I supplied them a couple of fatigue testing machines more years ago than I like to admit. I would also like to answer a few of the other questions that cropped up in this thread, I know they are old but it may shed a little light. Flame hardening is a very old technique which was used to surface harden relatively high carbon steels. The composition of the flame is irrelevant - this idea is to heat the steel very locally and then obtain a queching efffect due to the coduction of heat waya from the surface into the body of the steel. This technique has been replaced by induction hardening which uses an AC field and the 'skin effect' to locally heat the metals surface instead of a flame. The improvenemt in fatigue life offered by these process would IMHO be very limited. Annealing is a very straightforwad process. All Ferritic Steels are at their most simple an Iron/Carbon Alloy. Iron is only soluble at room temperature to around 0.02%. Whena steel writh more carbon than this cools it form a structure that comprises of iron and iron carbides. The morphology that results depends on the carbon content and the way it was cooled. Steels which have been hot rolled on a mill are often cooled quite quickly and be quite hard, steels which have been cold worked also harden. At around 723 degC steel will begin to change crystal structure from Body Centred Cubic to Face Centred Cubic and the solubility of carbon increases significantly. Depending on carbon content this process will be complete ast 960degC and a new single phase structure known as Austenite will be present. If the material is then slowly cooled, normally by the simple expedient of turning off the furnace and not removing the material until it has reached room temperature, the material will be in its softest condition. ie Annealed. Quenching takes place by heating the steel into the Austenite range and then rapidly cooling. As the steel tries to change its crsytal structure from FCC to BCC the carbon atoms which have migrated in the crystal lattice prevent this from happening as the tme domain available locks tham into plave (Fick's Second Law of Diffusion and all that) and a very heavily distorted structure results. This is known as a Martensite Reaction. To give a basic idea a file is a 1% carbon steel which has been fully quenched and not tempered. Last edited by chris_seven; 07-19-2010 at 11:12 AM.. |
Some random heat treatment links:
Abstract from Metal Science and Heat Treatment SpringerLink - Journal Article Abstract**Nitriding technology has gone a long way, from the old gas nitriding to the relatively recently developed plasma nitriding. The latter has replaced the process of soft nitriding in the automotive industry based on nitrocarburizing in cyanide salt baths. It seemed that the high toxicity of the initially used compositions for soft nitriding (Tufftride or Tenifer) should have eliminated salt baths from the industry. However, they are still rather widely used. The replacement of old compositions by nontoxic ones has solved fundamental problems of environment protection. Low-temperature nitriding technology also advanced considerably. Salt bath nitriding is a very active process, more intense than that of gas nitriding and nitrocarburizing including the processes of plasma nitriding. The reactivity of the nitriding medium and the final efficiency of the process with allowance for the cost of the equipment have to be taken into account. An additional advantage of salt bath nitriding is the possibility of treatment of stainless maraging steels. The present work is devoted to comparison of the processes of treatment in a nontoxic salt bath and in a gas medium and discussion of the advantages of nitriding in nontoxic salt baths. This company claims no difference between Tenifer or Tufftriding processes. cilindri telescopici telescopic cylinders v?rins telescopiques teleskopzylinder Varioius Melonite Ppocesses as performed by this US company: Melonite Processing Hope this adds to the confusion. Sherwood |
Salt Bath Nitriding
Sherwood,
I don't think that Dr. Funatani's paper adds any confusion. Salt Bath Nitriding is very common and very cheap in comparitive terms. Road car cranks have been salt bath nitirded for years and it is very cost effective compared to Gas or Plasma Nitriding. The great 'intensity' that they speak of means that processing time at tempertaure is short and hence cost, which is all about heating time is low. the current going rate in the Uk is a couple of dollars a pound. The 'diffusion layer' which relies on a solid solution of nitrogen in the steel is a well known phenomena that has been developed in the new replacements for the cyanide salt baths but I have yet to see any data of the level of residual stress produced or any real fatigue data. There are some claims that the nitrogen, which diffuses into the surface also produces finely dispersed nitirides and I feel that this is a claim too far. This will only happen if the correct alloy elements with the correct morphology are present as is the case in a nitriding steel. Some nitirdes can be damaging particulalry on the surface of a component. The introduction of Nitrogen into steel is a common practice and does have some benetfits. Treating ground and used cranks with this process seems a good idea and always has been. I would still use EN40B and gas/plasma nitriding if I needed the ultimate performance. |
crankshaft materials
Some info on the specific alloys and surface treatments used by the factory.
"With the exception of the 12-cylinder engine crankshaft the crankshafts of all Porsche engines which are now (edit Feb 1972) in production are made from heat-treated steel and tufftrided. This is a surface treatment in a salt bath at 570°C. Our measurements showed an increase of up to 50 per cent of the fatigue strength for tufftrided crankshafts. We could thus replace the originally used chrome-molybdenum steel in our 911 production engines (42 Cr Mo 4) by the less expensive carbon steel (Ck 45). Porsche uses tufftride or 'Tenifer' treatment for camshafts also. The crankshaft of the 917 engine is made from chrome nickel steel 17 Cr Ni Mo 6, as this shaft has to be case hardened because of its central drive." "The Development of the Porsche type 917 car" H. Mezger Proc Instn Mech Engrs 1972 Vol 186 2/72. Last edited by jcge; 07-19-2010 at 04:26 PM.. |
hardening treatments
From 911 WSM
"Subject crankshaft to Tenifer treatment for 120 minutes at 570°C (1060°F) then quench in deoxygenated bath. Following Tenifer treatment polish all bearing journals and running surface A, and ferroflux complete crankshaft." From 930 WSM "Rule for the Tenifer treatment in accordance with Tenifer 90 W PN 1053." From 993 Tech spec book (and 964 WSM) "Regulation for surface reconditioning: gas-nitro carbonated PN 2063.....Working surfaces of the main and conrod bearing journals polished after nitriding." Tenifer (nitrocarburizing) is a trade mark circa 1960 of Durferrit Gmbh In their own words...... "The TUFFTRIDE® process is known in English-speaking and Asian countries under that name, in Europe and German-speaking countries as TENIFER® and in the USA as MELONITE®. TUFFTRIDE®, QPQ®, TENIFER® and MELONITE® are registered trademarks of Durferrit GmbH." This PDF has a great amount of detail on the process and its effects on a variety of materials (including some of those alloys in the post above). Great reading for the engineers and materials scientists... Durferrit GmbH Tenifer process and properties overview PDF Last edited by jcge; 07-19-2010 at 10:58 PM.. Reason: trademarks, PDF |
[QUOTE=jcge;5462434]Some info on the specific alloys and surface treatments used by the factory.
"With the exception of the 12-cylinder engine crankshaft the crankshafts of all Porsche engines which are now (edit Feb 1972) in production are made from heat-treated steel and tufftrided. We could thus replace the originally used chrome-molybdenum steel in our 911 production engines (42 Cr Mo 4) by the less expensive carbon steel (Ck 45). /QUOTE] Very interesting as is the brochure from Durferrit. Do you know when the crankshaft material was changed? Looking at the notched bar data in the Duerferrit brochure it seems that the 'salt bath nitrided' CK45 has a notched bar fatigue endurance Limit of about 500MPa, whic is not bad and certainly a significant improvement on the untreated alloy. It is similar to SAE1045 This information does confirm my thoughts that standard cranks are not suitable for traditional gas nitirding. Of course if the test had been carried out on smooth rather than notched bars the improvemnt would have been much less in percentage terms. CK45 has a typical tensile strength of between 600 and 800MPa depending on detailed heat treatment. 42CrMo4 is a much more expensive steel and has a typical tensile strength of between 1000 1100 MPa. The notched bar Fatigue strength of gas nitrided 42Cr4Mo is typically around 800MPa. All about money really. It is lso interesting that the 917 used a 17CrNiMo6 alloy as I would typically describe this as a gear steel. It has a realtively low carbon content so it can be case hardened but straightening it after carburising and quenching must have been a real trick. |
