phe phe is offline
phe's Avatar
Send a message via ICQ to phe Send a message via Yahoo to phe
Help, advises needed
This is my SC (RS 3.0 look, track used)
We have opened the engine, two parts broken, One piston and one "hammer" (dont know the english name). There are the pictures.
Any suggestion is welcome !
Target: reliability and power.
Old 06-03-2003, 07:51 AM
Senior Member
Doug Zielke's Avatar
Looks like one "piston" and one "rocker arm" (hammer) are toast (broken).
Rebuild time.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 06-03-2003, 07:55 AM
phe phe is offline
phe's Avatar
Yep, but what do I put?
phe
Old 06-03-2003, 07:58 AM
Senior Member
Dismantle and inspect everything, and rebuild as required.
Old 06-03-2003, 08:01 AM
phe phe is offline
phe's Avatar
Doug,
I am in the middle of the rebuild.
Planned:
chain tensionner kit
reinforced clutch
close ratio gearbox and LSD
race seats
segments (now I have to think again)
Already have SSI, bilstein, torsion 19/29,C2 4 pistons brakes,......
This is a 204hp engine, I can rebuild with the same cylindre/piston (high compression), but maybe there are other possibilities...
phe
Old 06-03-2003, 08:24 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Phe,
I never learned Dutch or Flemmish, but my French is OK. I lived in Namur for some years. You can send me a private mail if you need some information but your English is very good.
I would suggest purchasing the re-build book, 101 projects, and Bentley at a minimum. Measure everything. If it is out of spec, replace it. I would seperate the halves and make sure there are no metal particles floating in the motor. What kind of head studs are on the motor right now? Should those also be replaced? I would look into doing the valve springs, guides, etc.
Your top photo is the rocker arm. I would have the valve on that cylinder inspected and pay attention to the piston.
Best of luck!
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 06-03-2003, 08:45 AM
phe phe is offline
phe's Avatar
David,
This is fun I live in Ciney(Namur/Belgium) !
I forget to mention that, but valves guides and springs were already planned, I have got the wayne's books and the Bentley.
My tentation is to go for a 3l2 pistons/cylindres for the SC. Another option is the 3.3 RSR (less interesting I guess). The wise solution is to rebuild with the same spec . I have 1 or 2 days to think about that and any comment is welcome.
phe
Old 06-03-2003, 08:55 AM
Author of "101 Projects"
Wayne 962's Avatar
I just bought the Mahle kit for building a 3.2 out of a 3.0 (short stroke 3.2). It's not cheap (about $3600 retail), but it is definitely the way to go for more HP. I'm ditching the CIS and putting carbs or and engine management system on there...
-Wayne
Old 06-03-2003, 11:48 AM
phe phe is offline
phe's Avatar
Mahle 3.2 kit is on the way.
Swap the CIS,good idea but here good carb are not easy to find.
Still searching for a solution But actually with the $/€ conversion, it could be a good deal to order from US.
I will try to get info from PMO
phe
Old 06-04-2003, 02:32 AM
phe phe is offline
phe's Avatar
First do I put 40 or 46 ?
Does it really worth the $$$ ?
I always wanted seach a setting, as my bill will be already huge why not put everything. I know I will not resist to that.
What about transatlantic support from PMO ??
phe
Old 06-04-2003, 02:59 AM
Wayne 962's Avatar
They are pretty good - all you need to do is bolt them on - they will be set from the factory to your car. Follow the tuning procedures in 101 Projects, and you will be set...
You can run either 40s or 46s. I'm going to run 40s on my short-stroke 3.2, primarily because I have a set onhand...
-Wayne
Old 06-04-2003, 03:01 AM
phe phe is offline
phe's Avatar
Can I still use my SC fuel pump without problem with the 46 carb?
phe
Old 06-04-2003, 03:23 AM
Super Moderator
cstreit's Avatar
Phe,
The best way is a newer higher volume lower pressure fuel pump. You will also need a regulator to manage pressure to the carbs.
The carbs use about 3-4psi of fuel pressure whereas the CIS uses much more (30-70?). If you use a tank return line before the pressure regulator I guess you could use the CIS fuel pump...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-04-2003, 06:00 AM
phe phe is offline
phe's Avatar
I have found the pieces of my piston:
Old 06-12-2003, 06:55 AM
phe phe is offline
phe's Avatar
Some of the new material :
PMO 46 are on the way from US.
I cant wait anymore ......
Phe
Old 06-12-2003, 06:58 AM
phe phe is offline
phe's Avatar
Any way, work is on the way.....
Philippe
Old 06-12-2003, 07:02 AM
phe phe is offline
phe's Avatar
Forget to say an ENORMOUS thank to the garage. They takes a lot of time in explanations, pictures,.....
I would recommend it (private mail) to anybody in France, I am very satisfied by the service (until now )
phe
Old 06-12-2003, 07:13 AM
Banned
snowman's Avatar
Great pictures..
Old 06-12-2003, 07:51 PM
