Todd Simpson's Avatar
Broken wrist pin?
How common is this and what might cause it? How does oil get to these parts?
Old 05-04-2004, 11:03 AM
Navin Johnson
TimT's Avatar
Dont look!! scary pic...
Piston breaking at wrist pin
'69 911 GT-5
'75 914 GT-3
and others
Old 05-04-2004, 04:28 PM
Navin Johnson
TimT's Avatar
Also, oil gets to the wrist pin via a squirter that is installed in the case. the squirter opens at 3 bar oil pressure I believe, and a stream of oil is sprayed on the underside of the piston..
the squirters werent installed to lube the wrist pin though... this was mainly accomplished by oil just being flung around the case... the squirterswere installed to lower piston crown temps...
I notice in your sig you have a 71T... this could be on the bubble for having squirters...
Some other engine gurus actuallly drill a hole in the connecting rod from the rod bearing to the wrist pin and pressure feed the wrist pin....
A guy who builds 1500HP engine told me that trick..
'69 911 GT-5
'75 914 GT-3
and others
Old 05-04-2004, 04:54 PM
Motor is a rebuilt 3.2, and went back to the builder to remedy this problem.
I wondered if the rod was drilled, interesting idea. This motor does have a center drilled crank.
Old 05-04-2004, 06:40 PM
Navin Johnson
TimT's Avatar
I just saw the'71T in your sig....
so if you have a 3.2 you have the squirters..
The fellow that told me about drilling through the rod to pressure feed the wrist pin builds drag motors...1500 hp etc..
'69 911 GT-5
'75 914 GT-3
and others
Old 05-04-2004, 06:47 PM
Wanted to clarify...the wrist pin bushing cracked. It was knocking pretty loudly around 3K RPM.
The shop that built it tore it all the way down, redid the rods and put it back together. All is well so far.
Old 05-15-2004, 08:36 PM
Nope...
Old 05-16-2004, 06:47 AM
