yes just got the book but haven't finished it yet just wondering if there was any additional guidance out there..Thanks
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
On removing broken dilivar head studs: I just tore down a SC case that had broken all 6 lower studs on one case half. 4 of the broken studs were several inches long but two were only protruding 1/4" from the spigot surface. The long ones were quite easy as I mig welded a spare head barrel nut to the end of the stud and then used a 10mm allen wrench to remove the stud. For the close ones, I cut a small square of thin sheetmetal and drilled a hole in the center to slip over the broken stud to act as a heat shield. Then I placed a head washer over the broken stud and mig welded it to the stud. Then placed a 10mm barrel nut on the washer and welded it to the washer. The heat from welding loosened the loctite and the broken studs were easily removed without damaging the spigots.
JB P.S. Does anyone have any experience using materials other than Loctite 574 as a case sealant? For some reason, I hate 574. For the last three motors I have built, I have used a product called Dreibond, available in small tubes through my Porsche dealer at about $18 ea. Works pretty good but am always looking for better ways to do things. |
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
If no one did anything without experience, nothing would ever get done. I'm not about to do brain surgery on my self, but building a 911 motoris not in that league. The mistake I made was not putting sealant on the #8 bearing OD.....so it leaks. All the machine work was done for under500 bucks. I made parts choices using common sense, not "conventional wisdom"....tho I don't ignore it. It was my first & only 911 engine(thus far). I've been beating on the engine for 4 years doing AX. It's starting to smoke some at start-up......and the pistons rattle a bit longer during that period so it's time is coming. Not getting it up to full temp before the first pass is gonna kill it before it's time, but I'll build another.....IT'S JUST AN ENGINE! Total cost was under 4500 and I recouped about 1200 from the previous one. Put it down to beginners luck if you must, but there it is.
JPIII Early Boxster |
Well, I put the engine up into car, and in process of connecting everything I had put the ground strap from the starter to the body on the wrong starter bolt. Will drop and do again.
steve old rocket inguneer |
MBruns for President
Well you can count me in for camshafts reversed, and distributor 180 degrees and add reference and speed sensor switched...
JB - Ralph used yamabond for his 3.5 build
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Not tighteneing the rockers shaft bolts enough, only went to the factory torque settings and had several work themselves out of position.
2008 BMW 320i 2006 Mercedes ML320 2004 Mercedes ML270 cdi 1998 Porsche Boxter 1988 Porsche 930 Targa (sold) |
Ran starter to build up oil pressure on 964 rebuild. Looked for oil leaks and big puddle under right rear. I had forgotten to tighten the hose clamp on the return tube. This is the one behind the hot air riser and it was facing the wrong way. Yeah, that was fun. Ready to try again.
3 restos WIP = psycho
EDIT: I just reread the post; it was confusing, but now I get it: you are actually bashing MM. Got it.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Now in 993 land ...
George |
Before I tackle my engine rebuild, I'm taking a flight out to Cali with my frequent flyer miles to take the Anderson class. The engine build will take me 6 months. So what? My time at home is free and its a freakin' hobby. This engine isn't powering the space shuttle. People's lives aren't at stake.
Bill G. '68 911 Ossi Blue coupe |
"...but if you have rebuilt a few engines in your career as a hobby mechanic, the flat six is just another engine."
George, Yes. That's called ........ experience. Sherwood |
Banned
It ain't just another engine. Its a specific Porsche engine, each having their own specific personality. If you don't know what that personality is, you could be SOL. Thats where the experience comes in. Just NO other way, except waiting 30 years and hopefully reading ALL of the problems that a particular engine has, and even then All of the problems are NEVER all published, are they?
So, engines have their own personality. So what? you painstakingly research that personality. I'm not saying someone that's built 100 engines isn't less likely to make mistakes than someone who's built 3. Sure, that's obvious. But, you seem to be saying unless you've built 100 engines you can't do a successful rebuild of the mysterious, incomprehesible Porsche engine. I'm sure I'm misunderstanding your point, though.
Now in 993 land ...
![]() I just am tired of people acting like these engines are so special that nobody can work on them, except Dieter and Karlheinz who were trained at the factory and know the engine's PERSONALITY! ![]() And no, Sherwood, it does not take experience to find out "if the machine shop machined something incorrectly" It only takes basic measurement tools and a spec book to look things up. And have I mentioned that you have plenty time to do so as a DIYer? Wayne has done an awesome job supplying excellent DIY books and this site. He has helped get us away from the secret handshake mechanics that want to make everyone believe that these machines are super-complicated technical marvels. If any of you guys still believe in those fairy tales, you should not be here and discourage folks. Instead, how about striking up an entertaining discussion about $150 canuba wax on the detailing discussion board. I'd love to read all about it. ![]() ![]() George |
I've read a lot of Snowman's posts and he is usually right in what he says.... Its just the delivery lacks a certain sugar coating
Banned
For crying out loud, all I stated was what the most common mistake in rebuilding a Porsche engine, ie lack of experience. THats not in any way a reason not to do it yourself and to do it right the first time, just most likely a fact.
Anyone on this forum or myself for that matter would have never attempted to rebuild any Porsche engine if we thought we didn't have a chance. Its just that if we did rebuild an engine and did make a mistake, almost any mistake, it was due to the lack of experiencen noit a lack fo attention to detail or intelligence. And those with all the experience DO make mistakes, usually due to overconfidence or lack of attention due to familarity. IE we all tend to get complacent or lazy. Especially with highly repetative work. But still its that experience that gives the pros the edge. And yes the REAL pros do take it to an artform, thats the final step towards perfection. There are 2 Jack Frosts. One the sweet sugarery one from the east coast and the other the cool frigid one, thats the faster one. Not to sweet, just faster. Last edited by snowman; 09-15-2005 at 07:13 PM.. |
Well said, Jack.
I think Jack comes across a little curt or direct at times - but I think the information he gives is valuable and his advice is good.
Thread Tools | |
Rate This Thread | |
