Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
cylinder boring?
is there enough material on the 78sc cylinders to bore them out so that 3.2 litre overbore pistons can be used or do i need to buy different cylinders?
Old 05-09-2004, 11:11 PM
Irrationally exuberant
ChrisBennet's Avatar
Just in case Wayne's answer was too terse... The 3.0 cylinder's sealing groove makes them undesirable for boring out. The 3.2's are the same diameter (95mm) but they don't have the groove so they can be bored out and replated. It may be cheaper to just buy a bored out set outright (from EBS for example) rather than buying some and having them bored out yourself. When I looked into this a couple of years ago it was cheaper to have EBS do it than having US Chrome do it. (EBS uses someone else.)
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-10-2004, 07:11 AM
WydRyd's Avatar
Guys, what's the max diameter the Carrera 95mm's can be bored out to safely?
I'm thinking of going 98mm!?!
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-11-2004, 05:04 AM
