Siena911's Avatar
Question Cannot pull heat exchanger from heads
Hi all
I've now stripped my motor, and due to the fact that I could not remove the exhaust (all the nuts were lilttle brown rust blobs) and there was no way I could get them off.
I then removed the heads, camtower and heat exchanger as a unit.
I was then able to cut off the nuts but now cannot get the heads to separate from the heat exchangers.
I don't want to use any force in fear of breaking something. It would seem as if the complete exhaust stud has rusted and now it wont budge.
Any tips/suggestions etc greatly appreciated
Cheers Jakes
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
Old 05-13-2004, 09:40 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Once you cut the nuts at the exhaust ports off you might try to soak the stud area with penetrating oil over night. Also get the cam tower separated from the heads. That way you can remove each head individually from the heat exchanger.
I would try a deadblow hammer or a rubber faced hammer to "convince" the studs to give.
Good luck,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-13-2004, 10:03 AM
Irrationally exuberant
ChrisBennet's Avatar
Get some real rusty fastener liquid and keep soaking it twice a day for a week. That's what I do when I'm only working on a motor on weekends. It doesn't always work but it doesn't hurt either.
A visit to a pro who removes more rusty studs in a month than you and I will in a lifetime might be in order. You'll probably be visiting one if you break the stud anyway....
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-13-2004, 11:36 AM
the nuts might have had a helicoil inside, that's still on the stud, keeping the stud from pulling thru the hole.
206 637 4071
Old 05-13-2004, 02:06 PM
