Siena911's Avatar
Question Removing Carrera camshaft woodruf key?
Removing woodruff key from camshafts.
In Wayne's rebuild book, it mentions to use a small screwdriver to carefully remove (pry out) the woodruff keys from the camshafts. Maybe it is just me but I could not get them out at all. I eventually had to tap it out using a small screwdriver.
How do you guys manage to get them out?
Are they meant to be that tight?
Will I have to apply force when I put it back together again?
Cheers Jakes
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
Old 05-13-2004, 09:44 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
They are tight sometimes. I tapped mine out as well. Check the woodruff key for small burs and dress is with a fine file. The camshaft is hardened. So its slot should be fine.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-13-2004, 09:57 AM
set a flat screwdriver tip right in behind it, horizontally, and tap with a hammer. it will roll right out of the keyway. try not to drop it into the engine.
206 637 4071
Old 05-13-2004, 02:04 PM
vichang4's Avatar
I had to use a set of channel lock pliers (wrapped with duct tape) to push my keys back into the cam. I used John Walker's method to remove them.
Vic
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 05-13-2004, 04:51 PM
Siena911's Avatar
Yep, thanks for the advice guys.
Now about that dropping it into the motor, yep I did that, Took me about half an hour to get the darned thing out!!!!
Jakes
Old 05-14-2004, 01:49 AM
oneblueyedog's Avatar
On bank 1,2,3 I had to beat it out with a punch after boogering it up with:
a small screwdriver
needlenose pliers
vice grips.
The cam and shims survived but I had to get a new woodruff key. Not really a problem.
78SC coupe, Silver Metallic
Old 05-14-2004, 06:45 AM
yes, large channel-locks for the install. don't forget to put the shims on first.
206 637 4071
Old 05-14-2004, 07:58 AM
